Originally Posted by stevec325
How many watts/channel would you say I am using at various volume levels...?
@ -20db (moderate volume level for extended music listening direct mode 3+1)
@ -5db (typical movie volume in Dolby Digital mode 5.1)
@ 0db (cranking it up for movie volume in Dolby Digital mode 5.1)
@ +5db (when the need for Pink Floyd arises
direct mode, 3+1 or 5ch stereo)
I am trying to get an idea of how hard I am driving the amp...
I'm concerned with heat, and want to make sure that I'm not driving it too close to MAX until I get the cabinet ventilation installed.
direct mode, 3+1 or 5ch stereo)I am trying to get an idea of how hard I am driving the amp...
It's impossible to say what percentage of the power you're pushing. The speaker's impedance curve is different than every other speaker on the planet and will have different power demands on the amp, the channel trims will change things, Audyssey will change things, etc.
The volume goes up to +18 so you're nowhere near the top. You'll be able to drive it to those levels for as long as you like. If ventilation and heat become an issue, then the protection circuit will kick in. Ventilation is still a good idea of course for the longterm survival of the receiver.
