Originally Posted by
jdsmoothie
Correct. The AVR cannot support 96khz FLAC file formats.
Thanks again for the reply.
In a
thread, it is stated that:
"There should not be a problem doing what you want. FLAC is not a format that can be streamed through HDMI, but it would be decoded into 96kHz LPCM by the player software in your computer. All AVRs should accept stereo LPCM, and most audio-player software should be able to create it from FLAC."
Now either foobar is not correctly converting flac to lpcm OR there is something wrong with the connection.
I believe regardless of what foobar does or does not, in the control panel I should be able to see "96khz" in the supported formats section, wouldn't I?
