Originally Posted by cpcat
Legacy formats such as Dolby Digital, DTS are no problem for the ps3. They are decoded to multichannel PCM just like the newer ones. Your AVR can't tell the difference it just sees the PCM. You CAN set the ps3 to bitstream the legacy codecs so your AVR can decode them (it will) but there's no reason to, just set the ps3 to LPCM and forget it.
Thanks a lot ! ^_^
![Vantage Point (+ BD Live) [Blu-ray]](http://cdn.avsforum.com/d/d0/50x50px-ZC-d07db017_B0018CWW3C-51A2X6F7wXL.jpeg)
