AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › One-and-Only PS3 as Blu-Ray Player Thread
One-and-Only PS3 as Blu-Ray Player Thread - Page 741
post #22201 of 31995
I have a question about the compatibility of ps3 LPCM format. Will the Pioneer VSX-1018AH Receiver http://www.amazon.com/Pioneer-VSX-10...1443456&sr=1-1 will be able to process the LPCM from the ps3 ?
Is the ps3 capable of 7.1? Thanks
post #22202 of 31995
Originally Posted by Wryker View Post
Just checked amazon- didn't find it - what item is this?
Originally Posted by jmpage2 View Post
I don't know what you were doing, but typing "nyko" in the Amazon search bar produced this as the 1st hit;
http://www.amazon.com/PlayStation-3-...1793978&sr=8-1
Yeah, that's is. As noted earlier, it's really cheap and it works well.
post #22203 of 31995
Originally Posted by Pugnax555 View Post
It can power it off. You just have to go to the 'turn off' menu item in the XMB.
I have a Harmony One for which I can create macros. While the Nyko doesn't have a pre-programmed macro which will turn off the PS3, couldn't I just create one myself? How many button pushes does it take to turn off the PS3? Also, what about turning the PS3 on? Could I do that with the Nyko dongle coupled with a Harmony One?
post #22204 of 31995
I just insert a disk to turn it on
post #22205 of 31995
Yes - PS3 does 7.1 PCM if your receiver supports it. I believe the 1018 does.
post #22206 of 31995
Originally Posted by cognitive77 View Post
I've had my PS3 for approx. middle of July. It's an 80GB Metal Gear Solid bundle version. Recently, while watching Blu-ray movies, the screen would flicker to black and stop playback. The movie won't come back on, as I would have to eject the disc and power down the system.
A few days later, I was watching another movie and it did it again. Flickering to black, but this time the movie came back on immediately. Later during the same movie, it occured again, but the screen flickered a purple screen, green screen, then back to the movie. Later again, it flickered to a snow/white noise screen, then back to the movie.
Any ideas on what this could be?
I find the PS3 is a little less susceptible to fingerprints and scratches than some standalone Blu-ray players, but it still has problems... just last night a rental disc had a greasy fingerprint on the perimeter. With about 20 minutes left to go in the movie, it did just what you described... black momentarily, then the movie picked up again. I knew the fingerprint was there before starting the movie, I left it on purpose to see how the PS3 would do reading through it. After that first bobble, the PS3 went black again for a long time (40 seconds maybe) then a still frame from the movie appeared and the PS3 just would not play any deeper into the fingerprint. I ejected the disc, wiped the fingerprint off with a chean cloth (I usually wash dirty discs in the sink and dry with a soft towel, didn't even bother with that this time) and the rest of the disc played without a problem. Blu-ray is more sensitive to fingerprints and scratches than DVD... which is not surprising... Blu-ray discs hold much more data than DVDs so the encoded Blu-ray data is much smaller and easier to obscure even with read-error recovery schemes in place.
post #22207 of 31995
I've just been using the XMB, but I'm thinking of creating a macro for my 720... It's a max of what... 7 or so to the left? If you go "too far" (you're only 2 or 3 over from the Users category) there's no harm other than a slight delay perhaps, then 1 or 2 up and select X/enter twice. Would be interesting as an intellectual excercise, if not a reason to go back into the Harmony software, since I haven't made any changes to my setup in the last year.
But realistically, using the 'manual' XMB method to turn off isn't that bad. AT least not bad enough that I've felt the need to pony up for a PS3toothfairy... Turn on, I have to put a disc (whether it be movie or game) anyway... unless I'm playing one of the downloaded games... in which case I have the DS3 in my hand anyway...
post #22208 of 31995
Originally Posted by bommai View Post
Yes - PS3 does 7.1 PCM if your receiver supports it. I believe the 1018 does.http://www.amazon.com/Pioneer-VSX-10...456&sr=1-1
can someone please confirm this does this receiver process ps3 LPCM?
post #22209 of 31995
Originally Posted by gwsat View Post
I bought a Nyko remote for my PS3 because I had learned that the Nyko USB dongle worked well with Harmony remotes. Indeed it does, I could not be happier, and the Nyko was cheap, to boot. Check it out at Amazon's Web site and you will see what I mean.
Can anyone confirm that this will work with the MX500?
Appreciate it.
post #22210 of 31995
I, too have passed on a ps3toothfairy because the Nyko USB dongle is good enough for my purposes. My Harmony can do everything I want with it, except turn on the PS3. Even that is no big deal because I usually want to load a disk when I turn on the PS3. The Nyko is very useful and in the immortal words of Gilda Radner's old SNL character, Roseanne Rosannadanna, "It was ril chip."
post #22211 of 31995
Correct Setting for Dynamic Range Control?
In this post in the BD shootout thread:
http://www.avsforum.com/avs-vb/showt...4#post14696564
respected ISF calibrator Jeff Meier (poster UMR) makes the assertion that Dynamic Range Control (an audio output setting) must be turned OFF in the PS3 to avoid screwing up certain audio tracks. It is set to ON by factory default.
What's the consensus here? Does anyone have any reason to contradict what Jeff is saying?
If not, we should get this added to the FAQ sticky thread, yes?
Personally I've left it ON in my PS3 and haven't noticed any issues so far.
--Bob
post #22212 of 31995
--Bob
I've noticed nothing and mine's on too.
post #22213 of 31995
--Bob
Bob, Jeff's findings have been confirmed elsewhere on AVS. You may want to look into the BD Software forum for the Iron Man (9/30) thread. In there, I believe Dave Vaughn and Ralph Potts both confirmed that when DRC was left to "automatic", it muffled the dynamic range of the TrueHD track. It has to be turned to off, according to them and a few others.
Here are the pertinent posts:
http://www.avsforum.com/avs-vb/showt...4#post14655334
http://www.avsforum.com/avs-vb/showt...c#post14655462
I don't remember the specific reasoning as to why it only applies to certain tracks (specifically IronMan's), but it does not affect all TrueHD tracks if I remember correctly. See the thread for more info.
You may want to try the owners thread of that AVS for better responsiveness.
post #22214 of 31995
Do you think turning off DRC in the PS3 is confirmed enough at this point that it should be added as a recommendation in the FAQ?
--Bob
post #22215 of 31995
It should never be used unless your wife screams it's too loud from the other end of the house!
post #22216 of 31995
Bob- YES! at least, IMHO.
post #22217 of 31995
I must say I hadn't noticed that the default was ON, because I definitely would not want to be compressing the dynamic range (of course it's hard to know what Sony really means by this and whether it applies to TrueHD as well as legacy DD). I always bitstream DD anyway, partly to avoid weird things like this cropping up with new firmware.
post #22218 of 31995
I had assumed it was actually enabling the "Dialog Normalization" function in DD5.1 tracks. This is the first I'd heard that it might be screwing up anything.
--Bob
post #22219 of 31995
Originally Posted by AndrewZorn View Post
First off, my PS3 is outputting in 1080p. The dash and games are 1080p. Now...
I first noticed this when I played my first Blu-Ray movie. I have an HP w2408h monitor that I'm using as a display. I have it because it has 1:1 and keep-aspect-ratio scaling options (which I didn't expect other monitors to not have, especially a Samsung!). I had it on 1:1 before trying to watch a movie. When playing a Blu-Ray, there was a small (~50 pixels?) border of blackness around the entire image. This is because it was being displayed at its native resolution (right?). For the sake of stress and movie-watching, I quickly turned it to the keep-aspect-ratio-but-stretch option. That's where it's been for a while.
So again, the PS3 is most definitely set to output in 1080p. Only when playing a Blu-Ray disc, it appears to be sending a '1000p' signal, or something... because it doesn't fill up the screen at 1:1. Has anyone ever heard of this, or am I just worrying? Because according to common sense, the monitor is scaling the image a little bit, and ruining 1:1 goodness.
Ok, so maybe no one has seen this or cares, but I figured it out:
PS3 has BD-specific settings. When I change it to do RGB instead of Auto, it works fine! YPbPr seems to do this just-under-1080p thing, I have no idea why. I had the PS3 on RGB so I did not expect this.
Just putting this up in case another poor sap happens to have the same issue.
post #22220 of 31995
--Bob
I would say yes, Bob. Reason being that even audio/video experts, so to speak, with high-range audio systems didn't realize that this could potentially be a problem until fiddling around with the Iron Man TrueHD track and observing that the legacy Dolby Digital track had more dynamic range than the TrueHD track.
On other sites some reviewers thought there was a problem with the IronMan soundtrack and/or disc and were considering bringing the problem to Paramount's attention.
It sounds like the default should be to "off" because when on "automatic" it is turned on when playing the TrueHD track of Ironman. Most casual audio/video hobbyists will never know to turn it off, so having it in the FAQ seems logical to me.
Brandon
post #22221 of 31995
Maybe this has to do with RGB being for computer displays? It makes sense now that you bring it up.
Brandon
post #22222 of 31995
Brandon
I've updated the PS3 FAQ recommended setting for the audio dynamic range control to Off. Of course for the most accurate audio reproduction it should be set to OFF since this feature is a compression function intended to limit the dynamic range of the audio. It can be useful for some people and certain situations to turn on compression, but again for highest fidelity it should be Off.
Ron Jones
post #22223 of 31995
+1
Why would anyone consider this a normal feature to enable or use this unless someone is sleeping or working in the same space/home while you watch a movie? I imagine it's quite like ripping a SACD to a 128k MP3/AAC in terms of lost dynamics.
Charles:
Earplugs are cheap. Just be sure they are attached to a dozen roses.
post #22224 of 31995
Is anyone else having trouble playing the Transformers BDV? Every once in a while when I start it up it says "This video cannot be played", but if I try again it's fine.
post #22225 of 31995
DRC does not always do anything to a recording. It depends on the recording and whether there are instructions in the encoded track on how to implement it. If they are missing DRC is a placebo otherwise it is a mess.
post #22226 of 31995
The PS3 menu says it's only for Dolby decoded to PCM or something like that?
post #22227 of 31995
I've started it up 3 different times over the past week and it's played fine every time.
Yes, it's for Dolby audio which is decoded in the player. If you bitstream the audio to the AVR then the setting will not affect it. Most AVRs have their own setting for Dynamic Range compression.
Brandon
post #22228 of 31995
I recently picked up a new PS3 80GB unit. Using HDMI (with Pioneer Elite VSX-91TXH to SXRD 60A3000) just before the disc fully loads there is a slight click/popping noise heard through my speakers and the "Option" icon appears briefly in the lower right hand corner of the screen. Does anyone know if I can remove the noise or what's causing it?
post #22229 of 31995
I have a Denon 3808 Receiver and PS3 and 5.1 speakers using PCM which works great. I noticed if I leave the audio settings on the PS3 at auto it selects all options including 7.1 and 5.1....and looks like it send a 7.1 signal to my receiver which outputs at 5.1...but if i make the ps3 audio settings manual and only select 5.1 it my receiver just shows 5.1...
Does it make a diff which setting I use in the end?
post #22230 of 31995
I got a new 80 gig ps3 and it wouldn't play blue ray or any games.
I had to send it back because it was bad but I then notice a black line of dead pixels on my brand new samsung 40-81.
my question is if the new batch of 80 gig ps3 are bad? I been told the ps3 did not make the tv go bad but your popping noise makes me wonder?
