AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › One-and-Only PS3 as Blu-Ray Player Thread
One-and-Only PS3 as Blu-Ray Player Thread - Page 848
post #25411 of 32084
Originally Posted by thehalogod View Post
I have a Logitech universal remote that I've set up to run just about everything except one of the most crucial components in my home theater set up - the blu ray player.
I've heard of the bluetooth to IR devices but I also hear they do a really bad job.
Do you think it's worth selling the PS3 just so that I don't have to use the stupid controller that always seems to need recharging?
Don't know where you heard this, but flat out wrong.
If you want to sell your PS3, do so, but it's pretty ridiculous to do so for the reason stated.
post #25412 of 32084
The IR things work great.
Also, get the stupid remote if the controller irks you. You can get one used for under 10 bucks. Heck I have seen pawn shops around here with the remote under 5 bucks.
post #25413 of 32084
Read the FAQ. Many viable options shown there. I'm quite happy with the Nyko dongle, which cost me all of $15, with my Harmony. Never dropped a single keypress.
post #25414 of 32084
Just buy the PS3 BT remote. I have one and it does a great job.
I can even turn the PS3 on and off with it. Job Done!
Seggers
post #25415 of 32084
I suppose everyone is happy with their PS3 as a BD player. Days without a post is probably a good thing. Personally, nothing new has made my socks roll up and down so I'm pretty happy with mine. If I were to (step up) it would likely be a mega-changer. I can see putting the Oppo BDP-83 in my theater and in other rooms, but I'm not going to scratch and claw to be the first in line to get one. I'm really very satisfied with my PS3. It has performed extremely well since the CODEC firmware upgrades.
post #25416 of 32084
I'm satisfied with my PS3 and my Panny 35 too. So much so, that I turned down the offer to buy the Oppo last week.
post #25417 of 32084
You can go into the Device Settings and turn on the "Auto Off" for the controller, so it turns off after 15~ minutes. To turn it back on, hit the button in the middle.
That way it doesn't stay on for hours and need recharging all the time.
post #25418 of 32084
What do you guys think? I personally would love a cooler running, greener, bit-stream capable BD player.
http://www.engadget.com/2009/05/13/s...n-store-at-e3/
post #25419 of 32084
Seems debunked already: http://www.avsforum.com/avs-vb/showt...1#post16451601
post #25420 of 32084
I ordered a harmony adapter for playstation3 yesterday from harmony PN 943-000029 for 66.78 shipped.
post #25421 of 32084
Debunked, then suddenly the rumors heat up again.
http://www.engadget.com/2009/05/14/w...ght-on-camera/
post #25422 of 32084
Pffft. Those are fake. It's a bad Photoshop job. I mean, look at all that grain. And besides, anyone can fab pieces like that and make a mockup of a cardboard box....
On the plus side, at least they improved the looks of the thing. I may decide to replace my 40GB this xmas.
post #25423 of 32084
new update version is now available on the PS3... downloading at this time
post #25424 of 32084
Firmware Update 2.76 is out!
http://www.us.playstation.com/support/systemupdates/ps3
Have you noticed any improvements?
post #25425 of 32084
I got it...another small update that basically doesnt do anything.
I just know mkv support is coming..maybe....someday?
post #25426 of 32084
They added copy/paste. To me this is significant.
post #25427 of 32084
Just out of curiosity.... what do you copy/paste
post #25428 of 32084
Read this:
http://www.us.playstation.com/Suppor...tml#copy-paste
post #25429 of 32084
nearly useless
post #25430 of 32084
If are talking about the PS3 as a BluRay player then my highest priority for a firmware upgrade is to be able to read NTFS USB drives. Then I could author AVCHD without to format a drive FAT32 and carve up the large video files into 4G chunks
post #25431 of 32084
With the MultiAVCHD program, FAT32 limitation is a non-issue for me now.
http://forum.doom9.org/showthread.php?t=143744
MultiAVCHD is very cool, it retains loss-less audio, has great menus, and doesn't transcode the video.
post #25432 of 32084
Anyone having problems with the latest 2.76 download? I skipped 2.70 because of all the negative stuff I read--probably stupid, but just to be safe. How is 2.76 so far?
Thanks...
post #25433 of 32084
It adds cut and paste. And speeds up the trophy comparison some. Otherwise I have not noticed any changes. I have a feeling it may be a preload for some functions that will be revealed later. For example some integration with Home patch 1.21 coming in the next few weeks. Or so the rumors say.
post #25434 of 32084
I downloaded and installed 2.76 this morning and it went well -- no problems so far. For some reason the version I had been using was 2.6. Was that the previous version or had I missed one?
post #25435 of 32084
You missed 2.70.
I've had no problems with 2.76 (or 2.70) on my 40GB. Watched "Taken," played some Stardust HD, and watched a couple of episodes of Fringe via Hulu/PlayOn.
Noticed no differences.
post #25436 of 32084
Thanks guys. I have an older 80 GB. Hopefully it goes smoothly.
post #25437 of 32084
Originally Posted by rdclark View Post
You missed 2.70.
I thought I had missed at least one update, thanks for the confirmation.
What can you tell me about playon? Trying to use the PS3's browser for watching TV episodes from anywhere has ranged from difficult to impossible. With playon would I be able to watch full length episodes from the ABC, Fox, etc. on demand Web sites? I can't do it at all with just the PS3's browser. Even with Hulu it's a hit and miss situation. Some stuff will queue up but when it starts to play, I get audio with a black screen. Not good.
post #25438 of 32084
I'm using PlayOn primarily with Hulu and a wired network, and it works flawlessly. PlayOn currently has deals with Hulu, Netflix, CBS, ABC (not yet live) and some minor sources like YouTube, CNN, and ESPN. Hulu, of course, has Fox and NBC as well as an immense collection of archival TV and films. It all shows up in the XMB and can be accessed exactly the same way you would any other PS3 content. PlayOn is $40, one-time fee. I highly recommend you give the free 30-day trial a spin; it's a snap to install and configure.
Of course you need to have a computer turned on and running it, and the computer needs to be fast enough for the reatime transcoding. Any dual-core CPU will be fine.
post #25439 of 32084
I have compared about 5 different players now to the the PS3 and have ended up returning them all as the PS3 is still my favorite. The pq is pretty much equal to all of them and the aq is superb as well. Plus the PS3 is so fast and gets constant firmware upgrades. The PS3 is a complete beast! One of the best electronic devices ever made.
post #25440 of 32084
That's why I have two !
