I have that same unit and just noticed that the fan has been kicking in to a higher speed lately...I'm not sure if it is the newer version on PlayOn that I'm using (I wouldn't think that it would require any more processing power from the PS3) or something else. It didn't happen last summer and room temps are kept in the same range and location / ventilation hasn't changed...weird.
![Vantage Point (+ BD Live) [Blu-ray]](http://cdn.avsforum.com/d/d0/50x50px-ZC-d07db017_B0018CWW3C-51A2X6F7wXL.jpeg)
Anyway, it could be the heat, it could be dust, but most likely its a combination of the two.
. Or nothing more than a well thought out business plan
