I am hoping someone has some insight on this issue. I have a PS3 slim hooked up to a Bose Lifestyle 38 System. When playing a dvd or Blu-ray. I sometimes get a pop when changing tracks or at initial startup followed by a drop in the audio for 1 to 1.5 seconds as the new track begins. If I have the pS# Slim set to PCM and not DTS or Dolby Digital then all is fine, howeer I am not getting the benefit of True Digital sound. I am using an optical line from the PS3 Slim to the Bose system. I tried changing the optical cable, a different PS3 Slim and had the same issue. From the research I did it appears that when the movie trailers are over and the movie is about to start it someitmes goes from stero to digital or vice versa which causes a break in the digital signal and than causes the pop. Same is true when jumping to a different track. You are interrupting the digital stream and starting a new one. I read a lot on line and it appears that other people are having the same issue with all sorts or receivers (not just the Bose system) when paired up with the PS3. To be honest the pop is only loud and annoying if the volume is above a certain level also it doesn't happen all the time. I can skip around between tracks sometimes for 20-30 mintues without issue. As I stated the work around is turning off Bitstream and using just PCM. With PCM I do notice the audio is not as robust as it is with bitstreaming 5.1 or DTS. Also my old PS3 that I had just replaced with this SLim was working perfectly without this Popping issue I have incountered.
ANy thoughts would be welcome. Thank you.
![Vantage Point (+ BD Live) [Blu-ray]](http://cdn.avsforum.com/d/d0/50x50px-ZC-d07db017_B0018CWW3C-51A2X6F7wXL.jpeg)
), since I never owned the PS3 before, any tips on setting it up for the first time?
