AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › One-and-Only PS3 as Blu-Ray Player Thread
One-and-Only PS3 as Blu-Ray Player Thread - Page 989
post #29641 of 31995
the ir2bt thread seems dead so i'll also post the info here
with the 3.50 update the ir2bt unit works fine
post #29642 of 31995
Hopefully I'll get my PS3 back with this update.
post #29643 of 31995
Originally Posted by Tom Thomas View Post
From the Sony PS3 Update page:
When Dolby TrueHD is selected as the audio format, audio will be output in Dolby Digital during playback of Blu-ray 3D content.
When DTS-HD is selected as the audio format, audio will be output in DTS during playback of Blu-ray 3D content.
http://us.playstation.com/support/sy.../ps3/index.htm
All the more reason to avoid 3D (which I was going to do anyway).
post #29644 of 31995
Thank you.
post #29645 of 31995
Originally Posted by PaulGo View Post
When the PS3 was designed 3D playback was not even a thought - they needed to use the cell processors for handling the additional 3D playback resources which did not leave enough cell processor resources to handle lossless audio decoding. It is alway possible tyat sony will figure out a way to better optimize the 3D decoding so they can implement lossless audio.
Agreed about decoding lossless, but it shouldn't require much to output a lossless bitstream (on the newer models that support it).
post #29646 of 31995
I was just about to say that. It should still be compressed sufficiently to be passed as bitstream.
post #29647 of 31995
Originally Posted by Darin View Post
Except, if I'm not mistaken, at least on the older PS3s, they don't really have a 1.3 chipset. I thought it was something like 1.2, and they did some software tricks to get it to operate as 1.3. Perhaps they're reaching the limitations of what they can do with the hardware.
That may be the nail in the coffin.
post #29648 of 31995
PS3 owners...Pwned.
post #29649 of 31995
Hey, when I purchased my PS3's a couple years ago there was no mention or promise that they'd be able to play 3D Blu-Ray's and it wouldn't cost anything for an upgrade. So it doesn't play all audio formats or Java but I don't have to go out and spend a few hundred dollars to play a 3D Blu-Ray, I'm happy at the moment.
post #29650 of 31995
Originally Posted by Yoeddy1 View Post
PS3 owners...Pwned.
Hardly the case.
post #29651 of 31995
3d
post #29652 of 31995
Updated my launch 60GB PS3 with only one hiccup. It plays blu rays just fine, but when I try and access the playstation store. It tells me it's not available in my country or region.
Anyone having similar problems, or possibly a solution?
post #29653 of 31995
Same problem I am just going to wait possibly the store is being updated.
post #29654 of 31995
There is no audio bandwidth limitation... all versions of HDMI have the same audio bandwidth (uncompressed LPCM up to 7.1 channels) and it is a separate function from video bandwidth. Audio travels on dedicated wires in the HDMI cable itself. All versions of HDMI also support video up to 12-bits... only 1.3 and 1.4 support up to 16 bits. Since we are mostly transporting 8-bit video, there's PLENTY of video bandwidth even with the frame-packing strategy used for Blu-ray 3D. TrueHD and DTS-HD bitstreams have a LOWER bandwidth than 7.1 uncompressed LPCM... roughly HALF the bandwidth if the TrueHD or DTS-HD is 7.1 channels... less than half if the soundtrack is 5.1.
It's difficult to know whether Sony's DD from TrueHD and DTS from DTS-HD is something done for convenience so they could get the release out sooner rather than later, or whether there is some permanent hardware limitation that will never be worked-around with a future firmware update. Someone at Sony probably knows the answer.
post #29655 of 31995
Update did not fix mine.
Next, hidden system restore menu for: Restore File System(tonight).
After that, I'm going to crack it open and clean and inspect inside.
post #29656 of 31995
Not true at all.... the audio packets are interleaved with the video and dependent on the video for master timing. To wit, the Asus Xonar's won't work with out video.
The fat PS3's ARE bandwidth limited which is why they cannot pass bitstreams. This is indeed the end of the road.
post #29657 of 31995
That is incorrect! The FAT PS3s are able to send 7.1 PCM audio which takes a lot more bandwidth than Bitstream TRUEHD or DTS MA.
The FAT PS3's HDMI chipset lacked the ability to make the appropriate HDMI packet headers to indicate the stream included the Bitstreamed Lossless audio.
post #29658 of 31995
Has anyone tested the PS3 with a DLP direct to see if the PS3 will output checkerboard to a DLP natively to only use DLP Link glasses?
post #29659 of 31995
Yes I have the PS3 does not output checkerboard for Blu-ray 3D movies with the new 3D 3.5 firmware.
post #29660 of 31995
Hey all, new to the forum. Before I get to the questions, here is my current set up:
TV: Samsung LN46A850
Receiver: Yamaha RX-V663
5.1 Speakers: Klipsch Synergy Quintet SL-III
Sub: Klipsch Synergy Sub-12
PS3 80gb
Xbox 360 Elite
All running through monster power center
I currently have the PS3 video out directly to TV w/HDMI and optical audio out to receiver under "DVD".
Xbox output is HDMI to receiver under "DTV/CABLE", and HDMI to TV.
Here are my questions, and please forgive me if the answers could be found on the forum; I did a cursory search.
1. Which audio setting on the receiver should I be using for the XBOX to play games and the PS3 for Blu-Ray (straight, straight enhancer, etc)? I have been using the straight enhancer setting but after some reading, have switched to just straight, or sur. decoder as it is my understanding that they are the same. Also, the PS3 audio settings are set to all of the options (linerar pcm, dolby, etc) at various hertz, what should I have these set to? I only have 5.1 speakers, but when I use the 7ch enhancer setting, it sounds the best, or loudest.
2. Could someone point me to some beginner information about the various codecs (DTS-HD, Dolby, etc) and to some information where I could learn more about the detailed audio settings (sur. decoder, etc.)?
Thank you very much.
post #29661 of 31995
post #29662 of 31995
Originally Posted by GoodmanOX View Post
2. Could someone point me to some beginner information about the various codecs (DTS-HD, Dolby, etc) and to some information where I could learn more about the detailed audio settings (sur. decoder, etc.)?.
These should help:
http://www.highdefdigest.com/news/show/1064
http://www.highdefdigest.com/news/show/1233
post #29663 of 31995
PS3 owners...Pwned.
Do any other BD players released in 2006 even play 3D discs?
post #29664 of 31995
2D video with 7.1 uncompressed LPCM audio would have a higher bandwidth than 3D video with a bitstreamed TrueHD or DTS-HD soundtrack. The 3D video bandwidth is only 10%-20% or so higher than the 2D video stream on average. Bitstream audio bandwidth is about 50% LESS than uncompressed LPCM. So Bitstream should be supportable unless there's some internal issue like running out of processor time.
The bandwidth of HDMI 1.0-1.2 is 4.9 Gbps. Up to 3.92 Gbps can be video with is PLENTY, more than plenty for 2D or 3D video. Yes, HDMI 1.3 upped the bandwidtth to 10.2 Gbps but this was required for support of 16 bit video at 1080p which doesn't exist in the consumer market. I don't believe there's a bandwidth limit for HDMI that's causing Sony to not (currently) support either uncompressed LPCM or lossless bitstreams with 3D video.
The Lumagen Radiance video processors expect to support 3D video and high-res audio (pass-through) with processors having HDMI 1.2.
post #29665 of 31995
Just updated my PS3 to 3.50 without issue. Also found out that Netflix just became available in Canada as of yesterday (Sep 22), so I signed up for my free month and hit the PS3 to sign up for my Netflix disk. Well, low and behold, there is already a Netflix app, and after a quick download I was watching Netflix in all of it's streaming glory.
Was the netflix app part of the 3.50 update?
post #29666 of 31995
I don't think that is the point. Sony was bragging about supporting 3D on the PS3 for years. All of that time they never mentioned the fact that its support would be crippled.
post #29667 of 31995
I haven't had a chance to update yet, but can anyone else confirm this?
post #29668 of 31995
From IGN:
"Unlike our American friends who currently need to use the Netflix DVD to experience Netflix streaming on the PlayStation 3, the Netflix application is available for all Canadians to download under the "What's New" section of the XMB (coming to the U.S. sometime in October)."
http://ps3.ign.com/articles/112/1122781p1.html
post #29669 of 31995
From IGN:
Dammit. When's that Microsoft exclusivity agreement supposed to end???
post #29670 of 31995
Please show me where Sony was bragging for years. I believe the first mention of 3D support for Blu-ray discs was in January, 2010.
