AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › One-and-Only PS3 as Blu-Ray Player Thread
One-and-Only PS3 as Blu-Ray Player Thread - Page 1044
post #31291 of 32083
I just ordered a 3d projector. How well does the play station do 3d and the 7.1 sound?
post #31292 of 32083
Has anyone had issues with the PS3 not playing nice with their projector? I just recently bought another PS3 for my living room and have it running into my processor and the output of the processor is run through a powered splitter to my plasma and JVC DLA-RS10. The PS3 works fine to the TV, but I get nothing to the projector. I decided to cut the splitter from the equation and run the output of processor directly into the projector and still nothing. I have an XBOX 360, Apple TV, NeoTV 550, HTPC and DirecTV box that all play nice, but the PS3 refuses. What am I missing here?
post #31293 of 32083
I have a 4 year old 40GB FAT PS3. I use it in a well ventilated area. Recently it has developed an issue whereby the fans kick up into higher gear after 10-15 minutes of a blu-ray movie or game. Its not in super jumbo jet mode, but it is quite a bit louder than my projector and very annoying, especially during quiet periods in a game or movie.
I've tried all the easy remedies, vacumming, blowing air/dusting etc but nothing has helped. Tried running it with cans under it as stands, didn't help, etc.
From what I read it may be the thermal paste and heat sinks. I'm not sure though because in those reports its YLOD or super crazy loud fans after 5 minutes.
In my cases I don't believe the fans are in the highest mode but they are definitely blowing pretty hard.
Anyway - I'm considering trading in my PS3 and putting the money toward a slim. Do the slims run much cooler and quieter, or might I have the same issue with that? If so that would be a huge waste of money.
There is a company I can send it to - looks like it'll cost me about $100 to take care of it. But at that point I could put that $100 plus some trade credit and for another $150 just get a brand new slim.
What do you guys make out of this and what do you recommend? Thanks!
post #31294 of 32083
Had the fat and now have the slim. Big difference but the slim is still a bit noisy. My fat was VERY loud, like a jet engine after 10 minutes. The slim fan can certainly be heard in a quite room but I would say it produces no more than 30% of the noise of the fat.
post #31295 of 32083
Thanks. When I buy a slim is there any trick to looking at the packaging to determine if its the latest and greatest hardware? I'll probably get the 320GB Uncharted 3 Bundle one since I planned to buy the game anyway.
Then again this seems like a silly time to make that purchase. I have to think that with Black Friday coming up there will be a better deal... Anyway if there is newer hardware with a cooler chip/components etc certainly I'd want to get that one.
post #31296 of 32083
Skyrim in 3D
Just got this game and have to ask how do you get it to play in 3D? When I installed the game, it downloaded an update. I believe it was in regards to 3D play. When I start the game now, there are warnings about 3D, but I can find nothing that allows me to play in 3D.
Any help will be much appreciated.
post #31297 of 32083
Originally Posted by Thunderduck View Post
Skyrim in 3D
Have you already PLAYED other 3D games?
There is a setting in the PS3 and Everything else needs to be 3D compatible
post #31298 of 32083
Yes, Uncharted 3 and several 3D movies. Also a 3D space game I downloaded but can't recall the name. Looks good when the ship explodes. I have a new Vizio 3D set.
Could you please advise what I need to do in the PS3 so that I can confirm I have the correct settings there?
Thank you for your help.
post #31299 of 32083
If other 3D games played on the PS3 - you should be good to go
post #31300 of 32083
In Uncharted 3, there is a menu selection I need to make to play the game in 3D plus the tv asks for confirnation when whenever a 3D source is played. Nothing like this happens when I start/play Skyrim.
Tks
post #31301 of 32083
Thunderduck, just curious where you got the impression that Skyrim is supposed to be 3D? I've never seen any mention of it being in 3D at all. In fact, I seem to remember seeing something about how the developers had zero interest in making their games in 3D.
post #31302 of 32083
So this thread is almost 6 years old.
Are there not better Blu-Ray players in terms of speed, quietness of operation, features, picture and audio quality, etc.?
How are the sub-$200 players compared to the PS3 for Blu-Ray and DVD upscaling?
post #31303 of 32083
Must have been an incorrect assumption on my part. When I loaded the game it appeared to download the same update that Uncharted 3 did. After the update there are all kinds of warnings about the affects of viewing 3D programs. Since, as far as I can tell anyway, Uncharted did not come as 3D I thought the both games would play in 3D after the update.
My bad. Will enjoy both games as they are.
post #31304 of 32083
Originally Posted by gamermwm View Post
How do I zoom in on the picture if it doesn't fill the frame using only the standard PS3 controller?
I want to watch Cars 2 in 3D and its not 1:78 but 2:35 or whatever so I just wanted to be able do away with the letterbox bars. Is this even possible without buying the PS3 blu ray remote? I haven't been able to figure out how to do it with the PS3 controller
Also, did they ever fix it to where you can watch a 3D movie in 1080p with 7.1 surround or is it still just 5.1?
Any help or knowhow would be appreciated as I haven't used the PS3 for much more than games
What type of tv do you have? I can change the aspect ratio using my sharp aquos tv. It gives me the option of 4:3,16:9,zoom,wide zoom or the best dot to dot. Zoom or wide zoom gets rid of the black bars.
post #31305 of 32083
I am curious to know the answer to this question as well.
post #31306 of 32083
In My Opinion - the ONLY Difference is in DVD Up-Converting.
For playing Blu-Ray Content - it is 100% Digital - NO DIFFERENCE.
The PS3 has never been a slouch in DVD Up-Converting.
ALWAYS REMEMBER - DVDs are Low Def and Converting from Low-def
to Hi-Def is always open to end user opinions.
I hope this helps. I'm am 100% HAPPY with my (3) PS3s.
post #31307 of 32083
does anyone know if there is a software download that will make a early gen PS3 region free as far as BD's are concerned?
thanks
post #31308 of 32083
Do you have the PS3 Slim? I am thinking of getting that on Black Friday.
post #31309 of 32083
I have (3) PS3 Fats.
The Slim can bit-stream Hi-Def Audio versus Converting Hi-Def Audio - as the FATS can do
post #31310 of 32083
Can I have two PS3's (about 30 feet apart in two different rooms) running two different games simultaneously on separate TV's ? Specifically I am wondering whether the controllers would "interfere" with the other machine. I would assume that each controller is paired via bluetooth with their own PS3?
post #31311 of 32083
Correct. Simply plug a controller into the USB cable to pair it with the console.
post #31312 of 32083
I have a "fat" PS3 that is just use for Blu Rays. The issue the freaking remote. Sometimes it pairs, sometimes not. To get it to pair, I have to hard start the PS3 (physically turn the switch) and hope it pairs.
Latest updates and Sony remote (new batteries). Any ideas.
post #31313 of 32083
If I "remember" correctly, that sounds like a Bluetooth board going out. Mine does the same and my Blu-Ray drive just died for the second time. I'm going to have them replace it as well when I send it in for repair.
post #31314 of 32083
I've been noticing an issue with my VSX 21 receiver playing Blurays in TrueHD 7.1 and was wondering if it had something to do with the PS3 (I have a slim)
When I put in a BD with DTS-HD MA 7.1, such as Tron: Legacy or Captain America, the receiver reads it as 7.1 DTS-HD MA (I only have 5.1 channels set up, but the receiver reads it as 7.1.
When I play a title with TrueHD 7.1, such as Transformer: DOTM or Super 8, the receiver reads it as TrueHD, but only indicates 5.1 channels instead of 7.1. It still sounds alright, just wondering why it recognizes differently between the two formats.
Does anyone know why this is? the rest of my setup is a Samsung 47' LED display, non 3D. Thanks!
post #31315 of 32083
Gotcha. Guess I'll live with it until it truly dies. Not worth the additional investment of getting it fixed versus getting an new PS3 (or other Blu Ray player).
Unless you know of a cheap place to buy the replacement bluetooth board (or even if it is user replaceable). I'm going to search, but if you already know please chime in.
edit: found the iFixit site and it seems easy to replace. Now I need to find the replacement board in stock.
post #31316 of 32083
I have heard of others replacing it themselves which is why I believed that to be the issue. Since my drive is out again though, I'm just going to have Sony replaced both the drive and the bluetooth card. I purchased a new Slim 160GB for myself, but my daughter wants me to get my old one fixed and give it to her for Christmas, as she still has a bunch of PS2 games, and my old one is a 80GB backwards compatible one.
post #31317 of 32083
Please forgive my reluctance to read through 1000 pages for an answer to my question. I have done tons of reading on the LPCM vs Bitstream and I am still confused by what the new PS3's can actually do. I just bought Black Friday 160gb Ratchet and Clank Bundle for $199.
Is this considered a slim?
Will it bitstream TrueHD?
This is what Sony's website says which is confusing to me...
"2.A device compatible with Linear PCM 7.1 Ch. is required to output 7.1 Ch. audio, supported by Dolby TrueHD or a similar format, from the HDMI OUT connector. This system does not support output from the DTS-HD 7.1 Ch. DTS-HD 7.1 Ch audio is output from a 5.1 or lower channel."
My system is 5.1 so will it support bitstream for DTS-HD and TrueHD? I am running a Denon AVR-5308 in my home theater with a Panasonic BD player but I want one for the family room I which I would be running with a Pioneer Elite VSX-30.
post #31318 of 32083
Post number 2 should explain it.
http://www.avsforum.com/avs-vb/showthread.php?t=931796
post #31319 of 32083
The slim PS3 (as opposed to the "fat" original design) is able to send bitstream HD audio to your receiver (via HDMI) so that the receiver can decode it. The "fat" PS3 could not do this. It had to internally decode DTS-HD MA and Dolby TrueHD tracks then send the decoded LPCM (also via HDMI) to the receiver. As it is all lossless (uncompressed) audio, the end result (what you hear) is the same.
The slim can actually do both (send bitstream or internally decode if you like). The only difference is that if you have the PS3 do the decoding instead of the receiver, the little DTS-HD and TrueHD LEDs on your receiver will not light up. It will only indicate incoming LPCM.
I just bought Black Friday 160gb Ratchet and Clank Bundle for $199. Is this considered a slim?
Yes. For reference:
http://seraphstudios.net/wp-content/...8/ps3slim4.jpg
Slim on the right, fat on the left.
Yes it will.
Based on the receivers you mentioned, yes. Bitstream or not has nothing to do with the number of channels (5.1 vs 7.1). That said, 7.1 tracks are much rarer than 5.1 tracks on Blu-ray discs. If you happen to get a disc with a 7.1 track, the receiver will down mix it to 5.1. No problem.
Bottom line for you based on the info you provided....
If you connect the PS3 to either of the receivers that you mentioned via HDMI and set the PS3 HDMI audio output to bitstream...
http://manuals.playstation.net/docum...ings.html#1470
...the receiver(s) will decode the DTS-HD MA or the Dolby TrueHD tracks. Do that and you're good to go.
post #31320 of 32083
Thanks for the help! I was waiting for an answer before I cracked the PS3 box, debating on whether to take it back and go with a dedicated Blu-ray player. Hooked it up and popped in Conan that I had just rented. The soundtrack sounded awesome and the DTS-HD lit up the front of the receiver.
Sorry, I missed the first page!!! I actually searched the forum with the terms "PS3 bitstream TrueHD" and everything that returned was from 2007 or 2008. I didn't even think to check the first page of 1045 page thread, assuming it would also be from 2007.
