Originally Posted by coda729
I have a PS3 Slim connected to Onkyo TX-NR708 receiver via HDMI. My problem is I have no vocal tracks in movies, and some voices from games are missing. There are several audio settings on the ps3 to adjust and I have tried several changes to no avail. Has anyone figured out how to set up the PS3 to get along with an Onkyo? Thanks for any help on this
Chris
Chris
I have a PS3 phat hooked into a SR805 AVR. No issues here. Everything is (very) loud and clear....
Do any other unit suffer the same fate? Are all the speakers working (testable by white noise from the AVR)? Is the PS3 set to output audio down the HDMU cable? Have you tired different cables? Is the 708 set up for the right HDMI channel for the PS3? Are you trying to shove audio into the 708 on component as well as the HDMI? Did you do factory resets on both (and the reset required afterwards)?
Give us an idea of what you've done, so we can get to the nub of the issue....
Seggers
![Vantage Point (+ BD Live) [Blu-ray]](http://cdn.avsforum.com/d/d0/50x50px-ZC-d07db017_B0018CWW3C-51A2X6F7wXL.jpeg)
