Originally Posted by nba23tsc
1. It is cable -> modem -> router -> wired to pc like the first one you describe. So I still need to get a network adapter for the PC to make the PS3 connect wirelessly to PC?
2. Oh. So the data in PS3 harddisk is totally useless outside PS3 even if I remove the harddisk and plug it to PC? Also once the data is inside PS3 there is no way to back up that data?
1. No, you don't need anything else. You should be all set to go. When you get your PS3 just connect it through the router (I assume you're going to connect it wirelessly). You may have to enter a WEP or WAP or other type of security key code depending on whether your router is secured or not. The PS3 will walk you through the steps to get connected. After you get it connected, go to the XMB (crossbar) menu under Video or Music and you'll see an icon that says "Search for Media Servers"--press "X". Then go back to your PC and there should be a window that pops up and asks do you want to allow this connection--select "Allow", then go back to the PS3 and do the "Search for Media Servers" function again, and it should connect to the PC. All of this happens through the router. By the way, all of your music, videos and photos need to be located in your Windows Media Player (I assume you have a Windows PC). Remember that this data is just being SHARED by your PC to the PS3, it is not downloaded onto the PS3.
2. Yes, you can connect the PC DIRECTLY to the PS3 with an ethernet cable to if you want to actually transfer the hard disk file data back and forth. Never done it, but the PS3 FAQ at Sony's website says you can do it. You can also download media files from your PC onto a memory stick or other type of removable storage media that has a USB connnection and plug it into the PS3 for access. I think you can also connect Bluetooth devices like iPhones to access media files on the phone, or if you have a USB adapter for your phone or Ipod you can connect it and access media files that way too. You can also use removable USB drives to back up data from the PS3 to restore at a later time. Remember not to change the file structure of the removable drive or the PS3 won't be able to access it. Removable USB drives have to be formatted in FAT32. Also, we're usually talking about a LOT of data for a full backup---a USB removable drive will usually require at least 32 or 64GB or even more depending on how much data is on your PS3's drive---and they are pretty pennies. 32GB memory sticks are 30-50 bucks a pop and larger ones cost A LOT more--and you can't split it up---all the data for the backup MUST fit onto one drive.
3. Let me know if this answers your questions---here's a link to the PS3 Users Guide: http://manuals.playstation.net/docum...ent/index.html
By the way, this is getting way off topic for this thread---the thread is for using the PS3 as a Blu-Ray player. Why don't you start a new thread and private message me with a link to the new thread, and I'll be glad to help you through getting this to work---
![Vantage Point (+ BD Live) [Blu-ray]](http://cdn.avsforum.com/d/d0/50x50px-ZC-d07db017_B0018CWW3C-51A2X6F7wXL.jpeg)
