However, the blu-ray player in ps3 is so robust and fast!
Also, ps3 is also the best dvd player that I have ever seen!
I own (3) PS3s and the Panasonic BLOWS the PS3 away in all departments for a PLAYERonly You should buy a Panasonic DMP-BDT220. for less than $150 and
see what a 4th Generation PLAYER will do. That is my two cent recommendation.
If you only use your PS3 for blu-rays, then you are much better off getting a standalone player. IMHO.
Just curious, I use my PS3 as a media player. I play AVCHD folders through an external HDD, stream from my PC's via PS3 Media Player, etc. Are there any standalone players that do that?
I sound like a fanboy trying to count the pro's to the PS3, but really I'm not. Certainly for Blu-ray playback only, there are less expensive and equal playback alternatives out there. However, in my case, since I use the media player like this (and it performs flawlessly), would I not be downgrading? Or do these new standalone players incorporate these abilities. The only reason I ask is that someday, the PS3 will bite the dust.
I know the Oppo players will do this, however, they cost 2x what a new PS3 costs. In your situation, I would replace a PS3 that has bitten the dust with a new PS3.
I personally think that the PS3 is a fantastic blu-ray player, I use it myself. However, the OP said that he only uses his PS3 to play back BD disks. In that case, I would spend the $150 or so on a standalone player and be done with it.
Out of curiosity, can the Panasonic be made to be "all region"?
Previous non-US models could, so the new models probably can too (see the 110 thread for instructions). But an easily hackable Insignia player can be had for $40.
If you're looking for a fast, quiet (compared to ps3) blu-ray player that also does SACD you should look into the Sony S580 - I got mine (Costco version) for right around $100 and have been thrilled with it. I use it for movies more than the PS3 now.
Most (probably all) of the Sony players support SACD as well.
Correct. See the BRDVD3 thread for details. There are links to all the hackable models, firmwares and procedures. I just sold my last one on ebay for $40 so it's kind of fresh on my mind.
I don't have many SACD. However, i want to have a very good "CD Player" for my classical music CD collection.
I have a HK 7550HD AVR.. I guess.. I will just use my HK DVD 48 to output digital to my AVR....
Yep, I would do HDMI from your DVD 48 to your AVR. If you want to spend $1000, you could get an Oppo 95 and use it's analog connection. I wouldn't advise that though.
I think to get the most out of your existing music you should evaluate your whole set up focusing on speakers and AVR (one with good audio processing) rather than the player. Oppo will give you bang for the buck in additional processing compared to a Sony BD player. That said my budget only allowed for a S380 when my fat PS3 died last month. Plays SACD for next to nothing thanks to ebay. Just look for a display unit, I got a steal since mine had no remote - easily remedied by using my cable remote to enable the smartphone app control.
SACD is NOT dead :-) There are a lot of is who enjoy and continue to buy these discs and for the jump in SQ it is worth it. But to each their own. I think it never took off due to the requirement of different hardware and I believe Sony has a large stake in this technology making it more expensive for other manufacturers to incorporate it. Why they took it out of the PS3 still irks me - it does NOT do "everything" anymore lol.
The thin PS3 is NOT A DARN THING NEW.
Can the Panasonic frame-by-frame back and forth on BDs?
I've also found the FF/REV scan on standalone players not worth much either.
