AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › One-and-Only PS3 as Blu-Ray Player Thread
One-and-Only PS3 as Blu-Ray Player Thread - Page 1061
post #31801 of 32084
Originally Posted by MI55ION View Post
If you ask me I think you've been unlucky. I've got a release day old ps3 'fat' and a 3 year old 'slim' both still working as new.
+1, except my slim is only 2 years old. Extremely happy with both.
post #31802 of 32084
Me three. I have had my PS3 Fat for 4 years and I gave my grandson one 6 months after I got mine. Both have performed flawlessly ever since.
post #31803 of 32084
i have a standard hdmi(ferrite core ones) cable going from my ps3(fatty) to my pio1018 my samsung has a high speed cable and looks better. i was shopping for new cables to hook up my htpc and saw that monoprice has a silver plated cable for sale for $10, should i get one for the ps3 or would i be better off with a normal high speed cable, or is the difference in picture quality "in my head"?
post #31804 of 32084
I buy all my cables from Monoprice and $10 seems pricey for one of their HDMI cables (what length are you getting?). I was just on their site yesterday and a 6' HDMI was @$3 (latest spec etc) and you can choose from different colors.
post #31805 of 32084
this one http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10240&cs_id=1024004&p_id=3658&seq=1&format=2 i was asking because i got some standard speed ones back in 2008 and i need more for my htpc and movies look better with the high speed cable attached to my bdp-1400 so i was wonderig if it was the cable or the player as i could always order a third cable
post #31806 of 32084
That cable is fine if you're going to run it in a wall - thus the higher price. No need to get that one unless you're running it through a wall. smile.gif
post #31807 of 32084
Originally Posted by DayWalkerSC400 View Post
Thanks for the responses! This is great news and super helpful. One last question, do you guys think a dedicated blu ray player will outlast a ps3 in terms of life span? I've used my ps3 only for blu ray and Netflix streaming and it died after 2 years. This unit was refurbished but the new console I had before that died after the same amount of time. I want a dedicated blu ray player because I am hoping it will last me longer. Think it will last me quite some time or what's the average life span?
ps3 should be fine just make sure you have a "optimal operating environment" i try to baby mine as i live in a cape and the ave temp/humidity gets pretty bad in the summer and there's no windows or a/c. if i had an a/c id try to keep it between 58-65F in the HT but back OT, it never hurts to have a back up player just in case if you have the funds cool.gif
post #31808 of 32084
That's what I use. I say get the best... we are literally talking about a couple bucks.
post #31809 of 32084
So I purchased BBC Life on Blu-ray here: http://www.amazon.com/gp/product/B002UXRGM0/ref=cm_cr_mts_prod_img
According to most reviews, this set should play fine on USDM PS3's. Well after the initial splash screens and video intro, it goes to a blank screen and refuses to even go to the Title menu! This is beyond frustrating. Is there such a thing as 1080p/50? Some people have said that my PS3 Slim , mfg in Sept. 2011, can't read this format. I checked and this release, although a UK release, is region free so that should NOT be a problem.
By the way, I'm running my PS3 through my Denon AVR 1910. Anyone know what might be going on?
post #31810 of 32084
You are out of luck... The PS3 cannot playback 1080p/50. Although the disc is region fee, the playback format is not compatible with NSTC standards. I think the US version is 1080i/60....
post #31811 of 32084
just lost my 60gb to the red blinking light; is it a better idea just to get a replacement unit for $99 and restore a backup from the old system? the only ps2 games i play are MGS, legacy of kain and FF-X. i use it as my primary bluray player(samsung bdp-1400 is my backup) is it worth getting a slim referb.
went with the try to fix, they sent me another 60 gb "referb" i got the thing around the beginning of march, go to turn it on today; fan spins up 3 beeps red light, one month out of warrenty. i called support and they said to call back on monday because there isnt a supervisor to approve another replacement 60gb. anyone else who still has a fat( and no a/c in a windowless ht den) how do you keep your system cool?
post #31812 of 32084
What is the deal in some dark scenes in Blu Rays where I see a lot of noise and there is a flashing phenomena. I've seen this in various different blu rays on my PS3 over time.
Just last night in the Blu Ray Journey 2: Mysterious Island I saw this in some dark scenes, and not in all.
Anybody know what's happening here? Blu Ray mastering errors? PS3 settings or problems?
Anyone?
post #31813 of 32084
Anyone?
Hi hardballpete, is the PS3 connected via HDMI? If so check if "Deep Color" found under "Display Settings Menu" is set to Auto ... if so try Off.
post #31814 of 32084
Yes on HDMI. Deep color is off. Super white was on, turned it off.
Anything else?
post #31815 of 32084
I've read the last couple pages and i'm having the same issue as a few other people. My Ps3 fat out of nowhere stopped reading disc. Last week I watched a couple movies and the next day it wouldn't work. The load icon spins but nothing. So today i called Sony's tech support and they said something was wrong and I could send it in for a $99 repair or just have to buy a new one. Not sure what to do and some advice would be greatly appreciated.
post #31816 of 32084
They offer a $99 refurbed Slim to me since I have the original fat 60gb w/ps2 compatibility - i decided to pay the extra $ to get mine repaired. Took @ 2weeks in total time.
post #31817 of 32084
Thanks. Mine is only a 40gb fat and thats why I was wondering if it was cost effective to spend the $100 dollars or another $150 more and get a new one with the warranty. The tech said it was only a 45 day warranty after they fix it and I don't know how they do as far as repairs go a year down the road. I did consider refurbished from them or my local video game store but used always worries me.
post #31818 of 32084
The warranty is the same whether you have them repair your unit or they send you a refurbed one.
post #31819 of 32084
Thanks for your help. So basically I have to decide buy new or take a chance with a refurbed one. Never bought anything refurbed so not sure what to do but I need one.
post #31820 of 32084
For $115 I chose to have mine repaired. If a new one cost $175 I'd probably have opted for a new one but they're not that cheap.
post #31821 of 32084
how do you keep yours cool? i dont have any a/c
post #31822 of 32084
You can always check local pawn shops. I go in the shops around me for video games pretty frequently and the cost for used units from them are $150-175 for the newer slim models. Most pawn shops offer a 30 day money back offer if it stops working. I have a 40 gig fat model I got a little over a year ago used from a friend for $50. Couldn't pass up that deal. Still working fine.
post #31823 of 32084
I have AC but it gets warm (the man cave is the second floor) but the PS3 is fairly well ventilated. I DO use CPU fans on my AVR to help keep the air blowing off it. They connect via usb on a usb hub to my Revu.
post #31824 of 32084
stupid thing died again; decided to go for a slim since they said i could have it for free, mom should be happy since it uses less power(and i can put the funds for a new player into getting a popcorn machine). are the video settings the same as the "Bertha" ones
Edited by swarm87 - 8/13/12 at 10:25am
post #31825 of 32084
Same here my trusty old PS3 keeps dying. I reflow fixed YLOD couple of times already. I used my PS3 only for playing blu-ray's and occasionally for DVD. I need to find player that has at least same quality blu-ray picture and also player should work fast as PS3. I already purchased Panasonic BDT110 a while ago and it is fast player but occasionally I find its picture lacking compared to PS3. Would it be best just to buy another PS3?
My old PS3 is fat version, how slim compares to it in blu-ray playing? I've seen tests that slim is slower but besides that is there any other difference (especially in picture quality)?
Anyone here found a standalone player that is definitely better than PS3 in playing blu-ray's?
post #31826 of 32084
^^ MY fat PS3 just died this weekend. About 3 days left in my 90 day warranty repair from paying to get it repaired when it stopped playing discs/games. Now it just 'died' (flashing red light - red light - green light -yellow light - flashing red light again). So I'll be sending it to them again for repair. We'll see what happens this time.
I have a 3D BD player I use for my movies now and regulated the PS3 to just a game player.
post #31827 of 32084
Originally Posted by Big Lebowski View Post
Same here my trusty old PS3 keeps dying....
I've recently replaced my PS3 Slim with a Sony BDP-S185.
Quieter, just as fast, same quality, and better for access to online channels like ABC iView, SBS Online, YouTube etc.
It's been excellent.
post #31828 of 32084
Thanks. You don't see _any_ difference in PQ compared to PS3?
post #31829 of 32084
All players tend to look the same with Blu-ray, because they don't have to do anything to the image to look good. There's more of a difference between players with DVDs, but that difference is getting smaller with time as the low-end players include better de-interlacing and scaling algorithms.
For a Blu-ray player I would buy based on the other features you want it to have, and not worry about Blu-ray picture quality.
post #31830 of 32084
I know it should be like that for some reason I see slight difference comparing PS3 and Panasonic BDT110. That's why I'm hesitating if I should just get another PS3 or is there a player that it really 100% equal to PS3.
