AVS › AVS Forum › Audio › DIY Speakers and Subs › Speaker cabs of a different style....
post #1 of 6
Wow!! Who know there was a newly created form for diy speakers. I orginally posted this to the DIY ..... and got no responses for over 3 weeks. But anyways here is a design that I thought might intrigue someone looking for something different for their next speaker build. My interest in presenting this is for the box design that can be used for a lot of speaker builds with volumes that suit this type of build. I used Peerless drivers for this particular build. I tried them with an old Dynaco amp I have and they sound great. I've built other designs that are not the usual box style. That's the beauty of DIY, you have creative control.
I didn't finish these as my brother-in-law wants to do that himself.
post #2 of 6
Very nice.
post #3 of 6
MCH, is there any chance you might post some construction details (plans ;) ) if some us wanted to build something like that?
-PGPfan
post #4 of 6
that's some of the best craftsmenship i've seen since Kingdaddy's center channel project. how long did the project take initially?
post #5 of 6
Slick stands!! Very good design.
post #6 of 6
Time wise it didn't take too long. The most time consuming was getting all the angles (especially compound ones) in the finishing detail. I build furniture as a hobby so woodworking is getting a little easier.
As for plans. Well I'm afraid I don't have the patience for a step by step layout explanation. The best I can suggest is visualize what you're doing and lay it out on paper. I'll make several drawings and then finalize the details on paper before I start the actual build. This build is basically a inner cabinet of 3/4" MDF with a 1/4" layer of veneering. The stands are made of 1" laminated mahogany (2 layers). There is a hidden channel to conceal the wire going up to the drivers.
hopefully this will give some inspiration to others for their build.
This thread is locked
