AVS › AVS Forum › HDTV › Local HDTV Info and Reception › Cedar Rapids, IA - HDTV
Cedar Rapids, IA - HDTV - Page 49
post #1441 of 4901
Actually, in central Iowa it says my TVGOS Host Channel is 11, which would be KDIN. When I originally got my TV, it did take several nights before I actually got data. Note that your receiver has to be turned off when the downloads take place. A 3 hour download window is usually scheduled for 3:21am, 8:01am, 11:06am, and 2:46pm. If you want to see if your set has even found any data to lock into:
Go into the guide by pressing , then move the cursor to the setup menu on the top bar. Press then 753159852. This will give you a gray screen with information on it. Press the button and there will be more info, but you're looking for the line that says "Host Channel".
So, for example, my host channel is listed as 1:0-11. The 11 in that line corresponds to the physical channel that have the TVGOS data embedded in the VBI. It also appears that the value at the top left of this screen shows when data was last downloaded.
post #1442 of 4901
Originally Posted by dline View Post
Now here's where it gets tricky: In the thick of the battle, Mediacom realized that Dubuque and Iowa City were close enough to Madison and Rock Island, respectively, that the FCC recognized WISC-3 and WHBF-4 -- both CBS affils -- as "significantly viewed" in those cities. By law, a cable or sat company can carry a "significantly viewed" station. So that's how Mediacom got around the Sinclair blockade in those limited areas.
There's one unknown: What did WHBF demand of mediacom so mediacom could carry WHBF in Iowa City?? I'll bet mediacom is not paying WHBF, but the problem is mediacom HAS to carry WHBF in Iowa City, but for how long? Would love to trade WHBF for TNT-HD
post #1443 of 4901
Last night, all of my channels loaded but none of the actual program listings were available, but this is progress of sorts.
Have any of you had a similar experience--channels one night, program listings another?
What do those of you who download TVGOS do about the order of the channels since they are not downloaded in the order that Mediacom has them in?
Nothing?
I think I might do nothing if I can do these two things, using the order that they are downloaded in...
1) If I am on a particular channel, say a movie channel, can I push the INFO button on my remote and get some of the same sort of info that I can get by using the Mediacom box--title of movie, date, starts, length, etc.?
2) If I want to do a basic search, as for example, for a title of a movie or program or of a sport (say, boxing), will I be able to do that?
Or is it necessary to re-arrange the downloaded order so that it matches the order that Mediacom uses?
If it is, is there a simple way to do this--something other than manually treating each channel?
post #1444 of 4901
You'll be able to do both of those tasks for searching & finding program information. The search is actually pretty handy as you can search by keyword, content type, or even if something's in HD. I rearranged my guide listing to match the mediacom lineup, but only because I've been so used to where shows are. It is nice being able to rearrange them, though, since then I was able to put my channels with HD at the top and then the rest of the lineup following that.
post #1445 of 4901
Interesting... Here is what I was told last night:
"The Gemstar supplied TVGuide information is a separate service and Gemstar recently signed a deal with CBS network for delivery. I don't know if this precludes PBS from a similar carriage deal but I haven't heard where they are on this."
post #1446 of 4901
Originally Posted by tsduke View Post
Does anyone know what channel Mediacom is airing KGAN-DT qam in Waterloo?
Is it even there?
Anyone?
post #1447 of 4901
Odd... guess I'll have to check it out at work now. Digital may be different, but I know before when Gemstar had approached KCCI they declined since the VBI is already being utilized by a live radar feed for county emergency management agencies.
post #1448 of 4901
Anyone?
Last I checked (although I record and watch OTA):
21.4 KGAN-DT
114.1 KWWL-DT
114.2 NBC Weather Plus
114.3 The Tube Music Network
114.4 KRIN-DT
115.2 KCRG-DT
115.4 KXFA-DT
115.6 KCRG Weather
post #1449 of 4901
Anyone?
I see it as 89.4 (fairly sure-Im at work) via mediacom in Iowa City
post #1450 of 4901
Is it working now? Do you know if this is using the analog or digital version of TVGOS? I got a report this morning of problems in the Waterloo area with TV Guide on analog, the viewer says Sony confirmed it was a problem with the data coming from PBS in his area (I'm not sure how they determined that).
It's possible that the little box at the transmitter that inserts the TV Guide info into the VBI has given up the ghost, or has corrupted information in it. GemStar is supposed to be checking it out since that is their equipment.
post #1451 of 4901
FYI: Mediacom (at least in Iowa City) lost KFXA-FOX on 6/26 both analog & HD. I'm told Mediacom analog is back on, but still working on HD (#828) & qam
post #1452 of 4901
At first, it was very static filled. Now, it seems as if there's a tape dragging, I believe they call it wow and flutter. Basically, it makes it unwatchable, happens up to 10 times every song! Has to be at the source, I'd think.
Just curious if anyone else seeing this. Kind of a drag, this has become one of my favorite channels nowadays.
post #1453 of 4901
Does anyone have the Mediacom HD DVR with HDMI output and can confirm with me that my box is working as intended. I am coming from Tivo so am finding the box to be very weak. When pausing the video, sometimes it continues for a few seconds, then jumps back. Rewinding and fast forwarding have no compensation for peoples reaction times, so when you hit play, it starts from exactly what you saw while in the FF or Rew mode. Also, my box appears to drop frames from 1080i sources, about one out of every 30 frames gets dropped, its very noticable (causes a jerky motion about every second) and annoying. Also, from time to time the HDMI output quits sending audio out, and also from time to time the Firewire output quits sending anything out to my DVHS VCR. Mediacom had me reset the box and redownload the software to it, but it is acting about the same still...
post #1454 of 4901
just 2 and pbs for ImOn qam still. Wish they did 9 and 7 so i dont have to switch back and forth or get a stb since my tv only has one tuner.
post #1455 of 4901
Anyone else lost all of their OTA digital stations?
post #1456 of 4901
Not very specific in your details, but I am getting all local channels just fine via OTA & Mediacom QAM....
post #1457 of 4901
I don't know what has changed from last night to today, but all OTA digital channels are coming in fine now...
post #1458 of 4901
KCRG is having their tower painted. This will require some off-air time that will affect all signals from the tower at various times, this would be KCRG and KRIN analog, and KCRG-DT, KGAN-DT, and KRIN-DT.
Most of the service affecting work is being scheduled for overnight hours, but wanted to give a heads up.
Work was to begin at midnight tonight, but it looks like it may be raining in that area so my guess is that they will hold off until tomorrow night.
post #1459 of 4901
In Waterloo: I assume weather is responsible, but last night OTA I could only get KFXA in. Oddly, although my KWWL OTA was out, it still came in through QAM on Mediacom, but neither KCRG and KGAN came in either OTA or QAM.
post #1460 of 4901
There was a power outage that affected the Walker and Rowley areas. Most of the locals do not have generator backups for the DTV transmitters (yet.)
KWWL likely feeds the Waterloo cable headend via fiber.
post #1461 of 4901
What are the Mediacom channels 961 through 980 going to be? They just showed up in line after the hd channels on Mediacom.
post #1462 of 4901
Nobody knows. http://www.dslreports.com/forum/r187...annels-more-HD
post #1463 of 4901
I just lost the OTA ATSC digital broadcasts from KGAN, KWWL, KCRG and PBS this afternoon. I still have KFXA. Of course this happened shortly after I agreed to record something for somebody on the digital stations tonight.
I still get KWWL over QAM cable in addition to KFXA.
Anyone else know what is going on. I'm guessing a power outage.
post #1464 of 4901
As of 4:15, I have KCRG and a good signal on KRIN but no picture. KGAN & KWWL are off air, which is strange since they are on different towers so I would not think it would be a power outage.
post #1465 of 4901
Obviously something big must have happened.
The good news is, it looks as if KCRG-DT is back up as of just after 4 p.m.
However, KRIN-DT appears to be putting out a signal but that signal has nothing decodable on it, and KGAN-DT and KWWL-DT are still out.
IPTV Digital is still operational on channel 12-1/12-2 out of West Branch (east of Iowa City) if you can get it.
post #1466 of 4901
The Eastern Iowa REC had a power failure this afternoon that affected the Walker tower that KGAN, KCRG, and KRIN transmit from, it also affected the Rowley area where KWWL's tower is located.
After power was restored an MPEG router at the KRIN transmitter site decided to come up on the wrong channel, so the transmitter had no data to transmit. A local engineer went out and pressed a button (too bad all fixes aren't that easy!)
post #1467 of 4901
You know, I hate painting a room in my house. Despise it, so I hire others to do it.
Do it at 2 AM 600' in the air...no thank you. I'm glad others have the courage to do it!
post #1468 of 4901
You have to wonder how good of a job they do painting in the dark. I'll never know, I'm not going up there to check!
post #1469 of 4901
Another power failure today during the thunderstorm. Power restored just before 6:00pm.
Was it just me, or was KWWL analog also off?
post #1470 of 4901
It's now official.
The FCC released its "final" list of channel designations (in .pdf) which all U.S. digital TV stations will have after 2-17-09.
(I say "final" in quotes because there's still a comment period.)
No real surprises for the Big Four Eastern Iowa cities:
- KGAN will (thankfully!) stay on 51 at 500 kW ERP.
- KWWL will return to channel 7 at 3.2 kW, which I kind of wonder about. (There's a channel 7 in the Hannibal-Quincy area which also plans to go back to 7; wonder if that has anything to do with it.)
- KCRG will return to channel 9 at 19.2 kW.
- KIIN will go back to channel 12 at 17.8 kW.
- KYOU (Fox Ottumwa) will return to channel 15 with 50 kW.
- KWKB will stay on 25 at 1 MW.
- KWWF, the former UPN affiliate in Waterloo, will need to flash cut on channel 22 to an 80.9 kW DT signal.
- KFXA will remain on channel 27 at 1 MW. WKOW in Madison will keep its digital channel 26 and abandon its current analog service on 27.
- KRIN will remain on channel 35 at 250 kW.
- KFXB, now a religious station in Dubuque, will stay on 43 at 800 kW.
- KPXR will stay on 47 and will be allowed 500 kW.
