Just curious if my fan noise is "normal". It's not any louder than my X-Box, but being a smaller fan its a bit whinier. Seems like after the cube warms up a secondary noise, almost like an electrical humm/buzz kicks in from the fan (I did check to make sure it was the fan). Maybe I'm just sensitive to sound. Does the gamecube fan adjust speed for temp?
- Cryo
- Cryo
