AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Harmony 880 Official Thread. For all info and FAQs
Harmony 880 Official Thread. For all info and FAQs - Page 20
post #571 of 6229
Originally Posted by czzer View Post
How could it be any easier? It only takes a couple of minutes to assign everything exactly how you want.
It deliberately doesn't make a guess at how you would like it set up, because it is a CUSTOM activity by definition. It isn't psychic...it doesn't know what you are trying to do.
It could ask you which device you want to end up using/controlling ... One step, no hassle. If multiple devices, a main one and then go to programming your keys.
Im not asking for the moon you know, it would not be very complicated to implement for Logitech.
Patrick S.
post #572 of 6229
Patrick S.
But the whole point of a Harmony is that you don't control a single DEVICE, you control an ACTIVITY. And a custom activity is designed so that it can be customized exactly how you want it.
post #573 of 6229
Why then it always default to my main device with I do not use a generic activity if it s not designed to do so ?
I get the point, but still having the default 'main' device keys already set when using a generic activity would simplify a whole lot the programming. You would only need to add the missing stuff instead of doing it from scratch.
I do programming all day at work and I don't expect to have to do it after work also ...
Patrick S.
post #574 of 6229
i love my 880. i got it all setup, the one thing i have an issue is this:
the button above 'media' the arrow pointing right, doesnt work like it should;
for example, if im looking at tv settings, and lets say theres 11 pages of settings, i cant use the button to go to the next page (2/11, 3/11, 4/11 and so forth)
however, the left arrow button (above 'device'), does function for viewing previous pages (11/11, 10/11, 9/11, 8/11)
how can i fix this? thanks!
post #575 of 6229
Patrick S.
This is a common misconception. It doesn't default to any device when you select an activity. It defaults to controlling the activity you select, not a particular device. For example, the "Watch DVD" activity is entirely independant to the "DVD Player" device. You can customize either of them completely independantly to the other. It's just that a "Watch DVD" activity implies that most of the remote buttons are going to control the DVD player, so this is how the software sets it up by default. However, it's also likely that the volume buttons will control your receiver volume.
For these type of "canned" activities the setup can make a pretty good guess as to what most buttons should be doing(depending on how you answer the activity setup questions).
But some people didn't like the setup guessing what buttons should do what and wanted more control over what an activity does, so they added the "Custom activity" option for these people...so they could set up an activity entirely from scratch. I guess no matter what they do, you can't please everyone.
post #576 of 6229
It sounds like it might be faulty. Return it for a replacement.
post #577 of 6229
I've got a Denon 2807 receiver, and I'm trying to figure out how to get the Harmony 880 to control multiple zones. It seems like I want a new activity that is "Listen to CD in Zone 2" that would set receiver to be in Zone 2 mode with CD selected as input, and set the volume controls to control the receivers zone 2 volume.
I can't seem to find an obvious way to do this. I tried learning a new command, but the Denon remote doesn't send a signal when you press "Zone 2", and it seems to send the same "CD" signal after I've pressed zone 2, or at least the Harmony learned the same one.
Has anyone done the same? How did they make it work?
post #578 of 6229
Hi there,
For those of you using the Harmony series (I'm using the 890, but I'm pretty sure the 880 is identical in this regard), I urge you to call customer support and seriously request that they allow the user to set the order of the custom buttons in the LCD screen. It's ridiculous that they have created their program so that it chooses the order that the buttons will be in.
Their number is 1-866-291-1505 (M-F 9am to 10pm EST, S-S 10am to 5:30pm). I called them yesterday and spoke to both first level and second level support. They acknowledged that this is a deficiency in their program and that they have had calls on it before. They were nice, but they would not let me talk to engineering and they would not let me have the source code so that I could fix it myself.
So, give 'em a call. This is just poor design, and if enough of us call, they'll eventually fix it.
post #579 of 6229
Originally Posted by OttoSpiral View Post
Hi there,
While your on the phone with them, ask them to change the programming for the Media button with Mega changers (CD & DVD).... The first breakdown (Alphabetical listing) only uses 4 of the 8 buttons.
post #580 of 6229
Originally Posted by NeedAName View Post
Is anyone using this with the MOXI DVR? I have that with charter cable, and its in the databse, but I'm just wondering how well it works with it.
Just wanted to drop a line letting Charter DVR (Motorola MOXI) customers know that this remote is working successfully with that box.
post #581 of 6229
I also use the 880 with a Moxi. It works fairly well. Some timing tweaks are helpful to get it right.
post #582 of 6229
Hi there,
Can you tell me exactly what you mean by custom buttons? I have a 880 and I know you can change the order of the buttons under the activities screen, you can do that from the activities listing on your home page. And I know you can maunally change the order, add or delete the listings under device mode, and also change the order of the listings in Favorite Channels under the Media button. What other area are you referring to in your post? thanks
post #583 of 6229
OttoSpiral is referring to the inability for users to re-order Devices. I called tech support and asked for this to be added several weeks ago.
post #584 of 6229
I am having some second thoughts about my 880. I have been reading on the forum that the 880 is buggy compared to other Harmony remotes and that the charging cradle is defective. Should I open the box and keep it, or switch to another Harmony remote?
post #585 of 6229
I can't say whether you should keep it or switch, but I got mine a few weeks ago and have absolutely no problem with the charging cradle or the LCD screen being washed out. Those were the two issues I read about and was concerned about - so far, no problem at all. I ordered mine from Dell. I was able to set it up pretty quick to operate my plasma, dvd player, a/v receiver, vcr, cd filer, and satellite box. So far, I have not encountered any bugs and the on-line database has been easy to access and use.
Of course, this is just one person's recent experience...
post #586 of 6229
I agree. The only thing I have noticed about the cradle is that when I place the remote on it, it doesn't always start charging. If I move it a bit, it seems to make a better contact.
As far as setting it up, it just took me a while to figure out how to customize things but I certainly*haven't found any*bugs.
post #587 of 6229
How can I add an MCE remote as a device to my 890?
I have a 890 and a usbuirt, Im going to use HIP I was hoping to add the MCE remote but I cant find it anywhere in the 890 "devices". The MCE already has a setup file configured for HIP, so If I can teach my 890 how to be a MCE remote, thats all I need to do, it will then work as a MCE remote system and the PC will respond accordingly... Im all for simplicity, although I spent 2 hrs last night trying to figure out how to achieve this....
post #588 of 6229
Charging Issue:
The charging issue is real if you receive one of the faulty cradles -- mine is this way and it takes fiddling to get it to charge. According to other posts here, Harmony is replacing these free of charge and presumably the remotes going out of the factory no longer have the potential for this issue (I will be calling mine in for replacement this weekend).
Button Order Issue:
I think that the button ordering OttoSpiral is referring to is within a particular activity, the order of buttons is defined by Harmony and not the user -- so the soft button layout in the "Watch TV" or "Watch DVD" activity isn't controlled by the user -- the buttons that apear there are, but not the order of the buttons.
post #589 of 6229
You can reorder the LCD commands in device mode and activity mode however you like. The only catch is that in activity mode the commands are still grouped by device, but you can re-order the commands within that device.
post #590 of 6229
Originally Posted by epie View Post
Hello,
Over the weekend I have noticed a proble with my PVR activity and looking for guidance. Currently it is set-up as follows (not that my PVR is on all the time):
1. Turn on TV
2. Switch to HDMI input
3. Turn on Receiver.
4. Mute TV
Seems very straightforward. My activity was working fine with steps 1-3 however step 4 has not been working reat since I added it.. My TV won't mute on start-up of activty. I have checked through the Device menu to mute TV to make sure it wan;t a problem with IR but that worked fine. Also, I went in and increased "Inter-key" delay up to 500ms and still I can't get TV to mute through the PVR activity button. This did work fine for about a day (only thing I did after it was working was update my remote with other stuff) and then stopped after the update (I think?)
Anybody have any ideas why something simple like "mute TV" will not work in my activity?
Thanks everyone!
Anybody have any thoughts on this?
post #591 of 6229
I agree with you. I can't figure what the other posters are saying. I have gone in to the LCD screen display on on the main activities, when in activity mode, and when in device mode and been able to add, delete and change the order of the items in all three of these. The harmony will start out with some default settings, but I have always been able to change them any what I wanted to.
And to answer smsprauge's question, I have had no issues with mine. It took me a few weeks and one call to CS to figure it all out, but now I love to log on and tweak it. I got all kinds of logos, pics, and special commands on there and it works like a champ, all for less than $150.
post #592 of 6229
Has anyone had any experience programming this remote with the Sony Sattelite receiver with built in PVR functions? I ordered this remote and I expect it to be shipped tomorrow but I'm trying to find out as much about the set up in advance. Also, does my computer need to be in the same place as my audio visual system? My network connection isn't wireless and all my broadband connections are upstairs and I want to use the remote for to entertainment stations, one upstairs and the other downstairs. Any feedback would be greatly appreciated. For the purposes of the reply I anticipate setting up the following:
Replay TV PVR (early model before Panasonic took them over)
Sony Sattelite PVR Receiver - Dirctv
Sony Wega TV
Panasonic DVD RAM Recorder
Toshiba VCR
Sharp Receiver
and Upstairs it's another DVD RAM Recorder by Panasonic
Samsung Sattelite Receiver with built in PVR
post #593 of 6229
Originally Posted by JBaumgart View Post
IMO this capability all but makes the video section of an audio video receiver unnecessary. On both of my systems where I use a Harmony I totally bypass the receivers' video inputs/outputs and rely on the Harmonys to do all video switching. Cuts down on cables and the direct connections don't hurt as far as picture quality is concerned either. When I see people on other threads fretting over upconversion and HDMI connections, I always ask why don't they just get a Harmony remote and when it comes to choosing their receiver/pre pro, just focus on its sound quality and other audio capabilities.
Because 80% of the TVs out there dont have Discrete Input codes.
Samsung is the worst!
Not only does it toggle from one input to the next but skips an input if no source is present!! Talk about a headache!
post #594 of 6229
Hi there,
Sorry for the delayed response to your original inquiry of my post. Everything I'm talking about is under an "activity" mode. So, I pick "Listen to Sirius" as an example, and I want to have two "pages" of custom buttons.
I want them to look like this:
Page 1:
Chan 1 | R2 Vol Up
Chan 2 | R2 Vol Down
Chan 3 | Chan 4
Chan 5 | Chan 6
Page 2:
Chan 7 | R2 Vol Up
Chan 8 | R2 Vol Down
Chan 9 | Chan 10
Chan 11 | Chan 12
I believe there are two problems with this layout, as the 880/890 currently sits. First, they don't allow repeats. I specifically set up R2 Vol Up/Down in the same location in all my "pages" so that I don't have to flip back to "page 1" to control the volume. Say all my favorite channels are on page 1 and my wife's are on page 2, so each of us likes to keep it on "our page" as we are using it. And, yeah, I could see making two "activities" for "Otto's Sirius Faves" and "Wife's Sirius Faves," but why? So they don't allow repeats, which I think is lame.
Second problem is that they grouped those according to the device they are controlling (in this case the "R2 Vol Up/Down" stuff is an Outlaw 990, and the "Chan XX" stuff is the Sirius receiver). After grouping by device, they group alphabetically. Because of the goofy way that the user must enter the things in the Java web app, in order to get my "page 1" example above I entered them like this:
Chan 1
R2 Vol Up
Chan 2
R2 Vol Down
Chan 3
Chan 4
Chan 5
Chan 6
Then, Harmony went ahead in grouping them by device, and then alphabetically to get this:
R2 Vol Down
R2 Vol Up
Chan 1
Chan 2
Chan 3
Chan 4
Chan 5
Chan 6
And that ain't what I want. Also, those "Chan XX" names aren't really in a nice alphabetical order like that because I'm using the Sirius names like "Chill" and "The Vault", so they are also reordered by alpha as well.
So, I admit that I have not tried to reorder them after they have been reordered by device by Harmony. It was painful enough to get them all "right" the first time (I created a spreadsheet where I could lay them out in the graphical order, and then it would reorder them for me to enter them in the list -- not complicated, but helped me "see" what I was getting, especially across all activities). I guess that gets me a little bit closer to what I want, but it doesn't solve the problem of me wanting to "double up" the same command in various pages, and it doesn't allow me to intelligently organize the buttons. It would be nice to always have R2 Vol Up and Room 2 Vol Down adjacent to each other (or however you like), but when I throw, say, "R2 Power" in the mix, they are further separated.
I guess I just don't understand (as a firmware engineer) how difficult this can be for them to fix. Actually, I don't even think this is a firmware limitation, as much as it is a self-imposed Java/web app limitation. It should be pretty easy to fix, and is a poor design from the start. IMHO, they have spent too many engineering resources on fluff (animated "screen saver", downloading your own pictures, etc.) that should have been implemented after the basics were 100% (GUI, web site, goofy crap like what I'm describing here, etc.).
post #595 of 6229
Sony Wega TV
Toshiba VCR
Sharp Receiver
No problem.
Just bring the Harmony into the computer room with a list of your devices and model numbers.
As far as the second room goes the Harmony will not let you do more than one activity at a time.
post #596 of 6229
Hi all, i've a question on adding custom labels in Activities
Currently, i've 3 activities
1) Watch DVD
2) Watch HD-DVD
3) Play Xbox
I've added a custom label 'Projector HDMI' to the activity 'Watch DVD'which basically sets the projector to HDMI input (in case the input does not set correctly when starting the activity)
However, this custom label is also added automatically to activities 2) and 3), which is not i want
Similarly, when i add a custom label 'Projector Component' to the activity 'Play Xbox', the label is added to activities 1) and 2)
How do i rectify this?
post #597 of 6229
- Unfortunately, this is one the major flaws of the Harmony programming. If you add a custom command for a device in an Activity, it adds that custom command to every activity that uses that device.
The only way to get around this would be to program a dummy device (Ex: duplicate projector) and only use that device in an Activity that you want the custom command. A lousy workaround.
If the real issue you want to correct is the missed input command, you should use the Help key to correct things or adjust your delays/repeats to make things more consistent.
post #598 of 6229
thanks bro. at least i know it is a flaw and not a broken remote!
post #599 of 6229
I assume these "Projector Input" commands are discretes?
If so, pressing the "Help" button(as tokerblue suggested) will re-send all discretes for the current activity, thus fixing the input problem.
If you really must have these commands on the activity pages, you can avoid them propogating by learning them to the other device in the activity. ie learn "Projector HDMI" to the DVD device, and "Projector component" to the X-Box device.
post #600 of 6229
Czzer, thanks very much for the tip! It worked!
  Back to Forum: Remote Control Area
