Originally Posted by
Codeman
Probably not, though some equipment does sometime support IR codes for which the corresponding remote wasn't designed. You would need to contact Samsung to find that out. If the TV itself does have discrete codes for each source, then the 880 can directly set them.
"Discrete codes" ... so that's the terminology I need to search for. Thanks! Googling brought up some hits for other Samsung DLP models ... I'll probably find some for my own if I search a little more.
However, since researching other remotes I'm getting the One For All 9910 remote instead. 7/8 as capable* as the 880 at 1/8 the cost. I also have a tiled floor, which makes it more important to get a remote that is cheap to replace if it's dropped and broken. The 880's color LCD screen is really cool though, it's almost worth buying just to see the "wow" expression
on my friends' faces.
*when enhanced with the "JP1" functionality
