I picked up the Polaroid FLM-2632 at Circuit City this weekend. I haven't had a chance to play with it much or calibrate it with DVE yet, but had a couple initial impressions. I purchased the Polaroid after returning a 26'' Syntax Olevia because of a speaker buzz issue.
The TV has a better picture compared to the Syntax, especially when viewed from an angle. I don't see any dead or stuck pixels after I spent some time carefully looking for them.
The TV makes an electric humming sound when it is first turned on and a faint electrical humm that once the tv is running. Anyone else with the set hear this when it is first turned on?
The ATSC tuner is able to lock stations pretty well even though I'm just using a small indoor antenna in a high multipath environment. It works better than my LG 3510 or the samsung set top box i used to have.
I was hoping to wall mount the tv using the mount that I had bought for the Syntax, but the configuration on the back of the TV is different. It is not the same VESA 75/100 that it looks like all other 26'' tv's use, but is configured like other larger LCD's. The mount I had to buy was more expensive than the smaller one's for other LCD tv's, so this decreased some of the price advantage of this cheap tv.
I hooked the HDTV cable box up using the component connections after I tried DVI to HDMI cable. I was getting sparklies with the HDMI. I don't know if it was the cable, cable box, or tv.
I really like the remote control that came with the tv. It is a larger remote than a lot of cheaper LCD's and is very comfortable to use.
After I calibrate with DVE, I'll post my settings.
