BritInVA Construction Thread - Page 13
post #361 of 1328
Sorry. I should have thought about mentioning this "feature" of the speakers to you when you asked about where to get banana plugs. It's been so long that I had completely spaced that I had that same issue. Call it a senior moment...
post #362 of 1328
Mark,
Thanks for the additional info and the pics also! I'm probably gonna use the bananas and just dremel off the bottom of the "T" on the bracket (or a portion of it). I have locking bananas that I'm keen to put into service...
Kevin -
post #363 of 1328
Kevin - a little more info:
This is the back view of the QS8 and the mount
The connections are not quite central and the mounting bar is in a shape of a 'T' so you cannot center over the outlet box (unless you cut the mounting bar).
Cheers,
Mark
it's hard to tell from the picture but could you unscrew the terminal cup from the back of the speaker and rotate it 180 degrees to give you enough room to sneak the banana plugs by the mounting bracket?
post #364 of 1328
I'm sure with a bit of tweaking banana plugs can be used - not sure I'll bother. Just surprised that the flaw exists.......or maybe my banana plugs are a bit long.
post #365 of 1328
My locking GLS's are about as long as they get. I don't think they vary too much Mark. JMFox poses an interesting question. Next time you have yours off the wall maybe you could peek at that for us......
Kevin -
post #366 of 1328
I sent an email to the main tech guy at Axiom. I'll report back what he says.
post #367 of 1328
Cool....
post #368 of 1328
I used the spade styled connectors the second time I mounted my QS8s. My first attempt I tried to use plugs and ran into the same issue. Now I just connect the cable directly to the binding post. Given that I never remove the speakers from the wall, not having the quick disconnect feature isn't a major loss. If ido need to take them down I can rest them on a ladder while i loosen the posts.
I second that notion!
crimp-on spade connectors are the way to go. Also the simple wire in binding post is good enough too.
post #369 of 1328
The Axiom guy got back to me. They acknowledge that spades or direct wire are the only way to go. They also recommend against trying to rotate the "cup".
post #370 of 1328
Thanks Cathan -
I'll have to see how this works in my own application before I decide how to go....
Kevin -
post #371 of 1328
Bill - Thanks.....didn't want to order something that would effect the quality of the sub(s). Only ones found that metioned LFE were long cables.
Got wiring diagrams for the shakers but still to select an amp to drive them.....so if anyone has recomendations appreciate it.
Not sure if you ever figured out what to purchase or already have......
Originally Posted by Belcherwm View Post
Alot of people have used PartsExpress subwoofer amps or I just used an old prologic receiver I had laying around. Ran the sub signal into the phone jack then out through the speaker outs.
Agreed. I used the part #300-796 from Parts Express. It's a plate amp. Around Christmas I think they have this "deal of the day" for a week. Got it for like ~$75 or something (normal $130). Also makes it nice that Parts Express is like 10min from my house! It's overkill for what's needed, but works great.
I have 4 of the Aura shakers wired to it. One in each of my risers, and two in my Berkline 090s. I split the sub pre-out on my main a/v receiver with a male RCA to dual female RCA splitter. I just got a cheap one @ Radio Shack.
Used #100-040 flat speaker wire for running under the carpet to the risers and chairs, and can barely even notice it's under there.
They're cool for movies with explosions and stuff, but for normal tv/music I keep them off.
Just my .02 cents....
Keep up the good work on the theater!!
post #372 of 1328
For now I've just used the wire directly into the bindiing post. Like Cathan says no big deal as normally once they are up thats it - but while I'm mid-build they will be down at times.
Its really not a big deal - just wish I hadn't bothered preparing with bannana plugs - that 10mins could have been put to good use on something else
I purchased the GLS Audio banana (referenced earlier in this thread) plugs to use with my Ascends. However, I ended up hard-wiring all my speaker wiring (Carol 12 guage) straight into the binding posts. All my speakers are either hidden in columns or behind the front-wall GOM, so it's not like they're going to be swapped out often. I even ditched the banana plugs on the receiver end and just hard-wired straight into the binding posts on the back. So, now I have a collection of paperweight banana plugs!
post #373 of 1328
Robert - I have considered one on the Parts Express plate amps but wanted something that slots into the rack.......so I'm just keeping an eye out for a cheap stereo receiver - no rush at the moment.
Going to continue to use the bannana plugs - does keep the equipment looking neat at the back (not that it will be seen).
Cheers,
Mark
post #374 of 1328
Some progress over the last couple of days. Got the side treatment framing done. This is a pic of what it looks like at the moment.
And here is a mock-up with the fabric added (if only could build it in a picture editor )
Will be continuing at a slow pace.....got the inlaw's coming over this week and off to Scottsdale next week - taking wife away (no kids) for 20th Anniversary.
Got a lot more woodwork to do!
Cheers,
Mark
post #375 of 1328
Looking good Mark!
Enjoy your trip, and Congrats!
post #376 of 1328
Yes, Enjoy your trip. Hubby and I just celebrated our 38th on Sept 7. This theater we are working on was suppose to be the anniversary present this year, to each other. unfortunately it is taking longer then thought and screen framing etc. has not arrived yet, lost in transit etc. You know typical stuff.
It is looking good.
post #377 of 1328
Mark,
Did you use the jig on those frames?
Bud
post #378 of 1328
Bud,
Yes, I used the Kreg Jig. Worked really well got the joints tight and flush. Some of the gorrilla glue did ooze out as it expanded so hoping that will sand off and not leave any blemish.
Cheers,
Mark
post #379 of 1328
Bud,
Cheers,
Mark
I went ahead and used typical wood glue, seemed to be fine, no expansion.
Bud
post #380 of 1328
Mark,
Any updates? Or has work ground to a halt?
post #381 of 1328
Bud,
Cheers,
Mark
Mark,
The GG will sand easily so no worries there. Those panels will look great. It would be nice if you could just draw it on the computer and click on the "EASY" button to make it happen in real life
post #382 of 1328
Why didn't anybody tell me you could just use the easy button! Doh!
Kevin -
post #383 of 1328
You must not have read page 2,135 of the Acoustical Treatments Master Thread carefully. It clearly states "or hit the easy button for a perfect theater experience."
post #384 of 1328
Crap! When I think of all the months I've wasted......
Kevin -
post #385 of 1328
Mark,
Cathan,
Things have definitely slowed as I had a lot of exterior maintenance to do before the weather gets too bad plus I had to build the kids playset.
Also had a mishap last week. Slipped with a drill and ended up drilling into the palm of my hand.....went in a fair way and lost ability to grip for a few days. Had me worried that I drilled into a tendon or something. But all OK now.
I've installed the door to the theatre and I'm making progress building the framework for all the panelling going in the rear of the theatre. Just got back from HD with more Oak.
Cheers,
Mark
post #386 of 1328
Originally Posted by swithey View Post
Mark,
Now that would be a worth while purchase
post #387 of 1328
How about some pics of the kids playset? I need to build one of these pretty soon myself
post #388 of 1328
Just so you know I'm not totally slacking here are some pics of progress today.
This is the panel been working on to today......see I'm making good use of the Kreg Jig
Closer image of the joints
And here it is up on the wall.
Hoping to get another panel done tomorrow but kids want me to put the Halloween decorations up also.
post #389 of 1328
Sorry to hear about your hand. That one sounds like it must have hurt. And I do know what it's like to be gimped. I've picked up a nasty case of tennis elbow myself. No clue how I got either. It's more than hampered my ability to tinker around the house. Matter of fact I'm icing it right now after having spent the day building wood valances for the bedroom. Injuries just suck.
Anywho, glad to know you made a bit more progress. Every little bit does get you just that small smidge to being done.
post #390 of 1328
As requested.......still need to put canopy up but will leave that till spring.
Cheers,
Mark
