BritInVA:
Membrane traps work on pressure areas.
In this graph (from the Harmon website), the top of the curves are pressure areas, and the bottom of the curves are not. I've drawn green lines where I think your absorber is in your room. So any spot in a green area, that's also high on the curve, is a mode that may be affected by your absorber, assuming it resonantes at that curve's frequency.
This assumes your walls are 100% reflective.
Looking at the 91hz yellow curve, I'd guess BINGO.
Putting the bar 5'9" to 6'2" (ish -- you could work it out better) away from the rear wall (yellow, blue, red; mostly yellow since yellow is 90ish hz and your absorber is 100ish hz), and the subwoofer 6' away from the front wall (non-energize the black mode), might be an option.
Tangental and Oblique modes may be affected as well if there are pressure nodes there. But I'll leave calculating those to you.
and my moulding is due to arrive Friday also
Besides it gives me an excuse to stay in the basement and get some work done. Here is a pic of the back yard the day after our 6 hour blizzard:
