Originally Posted by
Jagonfox
Anyone running something like this? I'm curious how you like the setup and if you like the overall performance.
2x T55s
2x B15s
1x C40
1x Subseries 1
Denon 2309ci
The reason for the sub series 1 is because the dealer I purchase from only sold the 6i as well and because I live in a condo with the t55s a 6i would be extreme overkill for an extra 400 bucks.
The c60 is the closer match to the t55s. Id go c60 is only for the greater power handling. However, the very best match would be a t55 center.
Don't underestimate the importance of a good sub. Its not always about output. Once you give up extension, there is NO getting it back.
The Denon 2309 is a fine unit, but I've found the Images really don't mind having a beefy amp behind them. Denon is a fine name brand, and that model has a healthy set of features. HOWEVER, if you don't need any certain features, you can most likely do a cheaper receiver with preouts + outboard amp, for a very comparable price. Just FWIW. my 2 cents.
Rÿche 1
So, Saturday Audio will ship? I can't find any PSB dealer close to me...I tried calling DMC Electronics, and I would not recommend them at all...They basically hungup on me, and were very rude
Wow. I think David is a great guy. I've bought from BOTH dmc and saturday, and I can recommend both, but its with dmc that I found better service and prices.
I just bought Ascend 340SE's last week, then I found out about the PSB T65's...Not sure what to do now, the T65's look awesome...Any thoughts?
These are two totally different animals, man. The T65s are quite large, particularly in their depth, I find. The 340s are, well, bookshelves. Oversized perhaps, but bookshelves nonetheless.
