AVS › AVS Forum › Audio › Speakers › PSB Speakers Owners thread
PSB Speakers Owners thread - Page 75
post #2221 of 4581
Originally Posted by Vise View Post
For about the same price I could go with the T5 main, C5 center, and S5 surround (my original preference) or alternatively the T6 main, C5 center, and B5 for surround. This is for a 5.1 setup with an SVS PB10 sub in a 13x15 basement rec room used mostly for TV/movies.
That's a pretty small room, as such I'd probably go with your first choice. Two reasons:
1) you don't need the T6 in that size room;
2) you are likely to have to have the surrounds somewhat close to your listening position in that size room. As such I'd want them as diffuse as possible.
Third reason is that I like the PSB S5 in general (or at least it's predecessor, which I have), but that's a personal bias...
post #2222 of 4581
Thanks, I was thinking the exact same thing on all counts but just not 100% sure. Your comments help though.
post #2223 of 4581
Originally Posted by Pete View Post
Why would anybody buy an older less-advanced speaker design when the new more-advanced model is readily available? I could see buying last year's automobile if all you need is transportation. But PSB wouldn't introduce a new range of speakers unless they felt that they could deliver significantly better performance for roughly the same money.
There are deals on T45's and 65's because I'm sure PSB dumped their old inventory to those dealers that like to promote big "save" stories. If you want the best performance, buy the new Image. If you want a low price, buy the old Image. Just remember that anything you think you may be saving will be accounted for in the re-sale value.
Don't be so over zealous about new designs being better than old ones. There are many cases where older designs were better. Take the new mid level entries from Yamaha as an eg. More features on the new series than the old Yamahas but also 10 10lbs lighter. That to me shows a serious compromise on the power supply design of teh new series. The amplfier section in my 4 year old Yamaha RX-V1800 will mop the floor with Yamaha's new RX-V2065 dispite that the RX-V1800 is liek 4 years older because the power supply is way more substantial.
You really need to get past this paradigm (excuse the pun) and sit an audition the two series. If the older T45s sound just as good to you as the new Image T5s, why would you shell out more cash for the new speaker? Doesn't make sense.
post #2224 of 4581
Power supply design has come a long way in the last 10 years. Switching power supplies are now the norm: they use smaller transformers which results in way lighter designs and better conversion efficiencies. The net result is a far better design than the older heavier power supplies.
post #2225 of 4581
There are no switching power supplies in the Yamaha receivers so that cannot be used as an excuse for Yamaha's weigh reduction. Switching power supplies have been around far longer tha people realize, approximately 30 years if not longe, first used in military aircraft applications.
post #2226 of 4581
I'm really itchin' for some pro Image T5 reviews. Has anyone come across any?
post #2227 of 4581
Even regular power supplies are getting more efficient, takes a lot less metal to get better efficiencies these days. Similarly, designs don't run class A or AB any more; the concept of switching has moved out of the PS and into the entire amp design. Makes a lot of difference to efficiency.
Sure, but they no longer generate tons of electrical noise, and are now cheap and easy to mass produce. We can thank the aircraft guys (and other places where weight was important), for driving the whole area of development. It's lead to some really efficient ways of using power across the board.
post #2228 of 4581
So far none of the receviers have been tested yet to see. The efficiency rate must be made very high to shed 10lbs of weight.
post #2229 of 4581
Well my old Michaleson and Austin TVA-1 weighed something like 80 lbs and put out 50 watts Class A. I've got a bunch of Sonos boxes hanging around the house that put out 50 watts Class T (or whatever) and maybe weigh 10 lbs total including a whole lot of other stuff (Ethernet, Web Server, etc). They have less distortion and produce far less heat and frankly, sound better (unless you're one of those people that like lots of 2nd harmonics). So 10 lbs doesn't seem like that much to me.
People got all bent out when Denon did the same thing going from he 3808 to the 3910. I don't get it, these days, judging an amp by it's weight makes about as much sense as expecting a sports car that performs well to weigh a bunch more than a poorly performing one... Save those materials, reduce the inefficiencies in design: smaller, lighter, more features, better performance, all sounds like a win to me.
post #2230 of 4581
Power amps have always been judged by weight as bigger heavier power supplies (read large transformers and capcitors) can store more energy for the amp section to draw against during loud passages.
Two of the transformers on your Michaleson and Austin were for the output stage, not the power supply. Tube amp output transformers are very common to match impedance between the final amplification stage and the speakers.
Your Sonos most likely contains a switching power supply and a class D switching power amp.
As far as "sound," tube vs transistor quickly becomes a holy war. My preference is for tubes, but it is more and more difficult to find good tubes at a good price these days
Cheers,
jr
post #2231 of 4581
Yup, time to move on. Technology certainly has...
Yes, and that's part of the point: you just don't need all that extra weight hanging around to produce that such limited output...
Umm, yeah, that was the point...
I've got no argument with people who say they prefer the sound of tubes. My argument would only be with people who claim that tubes are somehow better than non-tubed. In my book, "better" can only be defined by how faithful the output was to the original input. Whether you like or dislike that form of "better is, as you say, a preference. Personally, I find it the distortion introduced by tubes pleasant for a while, but tire of it over long periods of time....
post #2232 of 4581
Just wanted to pop in and say after 7 months of ownership of a Synchrony Two surround setup I couldn't be happier.
Choosing between the PSB's and the Monitor Audio GS setup I had in my room at the same time was the hardest audio decision I've made, but I chose wisely for myself and my room.
Fantastic speakers and the Synchrony One's for mains may be in my future
post #2233 of 4581
I grant that there may be some instances where older designs are better...just not very often and not in this instance. I'm familiar with old Image and new Image, and the new Image is better (better imaging, better low end loading, better power handling, better looking). I'm not being over zealous. I'm just stating what for me is a fact. Others who have not compared these two series of speakers or who are not familiar with my impeccable judgement, might confuse my statement of fact for an opinion.
post #2234 of 4581
A few months ago I bought a small two channel system for our living room, Marantz pm 8003 amp, Marantz 5003 cd player and some Paradigm Atom Monitor v6. The Atoms sounded too small and lacked bass, they were exchanged for the Studio 10 v5. With the Studio's there is alot of tweeter hiss which I would like to get rid of. I've read that PSB speakers are very good and was thinking of trying the comparable model to the Studio 10, also considering the B&W CM-1. Has anyone listened to both the PSB's and the Paradigm's or B&W's?
post #2235 of 4581
Okay, I've made up my mind to take advantage of the prices on the old PSB Image line for a 5.1 setup, and I need some advice on the following setups...
T45/C40/B15 because they are all size matched, but I'm worried about losing the bottom end as I'm doing 50/50 HT and music. Also worried for multichannel music that I'm giving up range in the rears with the B15. Best price, too.
T45/C60/B25 because of the above and size-placement constraints, but I'm concerned about the size mismatch not being optimal. From what I've read and heard, though, this is probably my preference for each piece of the system.
T55/C60/B25 because by all accounts the T55 sounds richer and goes deeper and they are size matched, but I'm concerned that the T55 has been reported as "boomy" and not as accurate as the T45. I'd love to go T65, bt I'm stretching at this point as it is.
Help! The room is 16x22x9. I have a decently musical Polk PSW111 sub that I will be replacing or adding to with a HSU or SVS as $ and the missus permits.
Any input is appreciated. I'm itching to pull the trigger and stop driving myself and the wife mad with indecision.
post #2236 of 4581
I'm going to listen to a pair of PSB Image B5s tomorrow. I'm assuming I couldn't pair the C60 with them and I should go with the C40. Assuming I like them over the B&W 686 or Energy C-10. What 2 or 3 stand options would you recommend? What looks cool? I know it's personal preference but I'd like to hear your opinions....I'd be going with the Dark Cherry.
post #2237 of 4581
My room is 22'x12'x8' and I'm using B25fronts/C40/B15 rears along with a 12"sub.
The B25 fronts have good extension and are more than adequate in filling the front soundstage and the C40 is a perfect match for them. The B15's are obviously more limited in range than the B25's but make great rears.
This set up fills my room with very detailed enjoyable sound for both movies and music although its main function is movies.
I wouldn't get the T45's over the B25's (I auditioned both). The only change I might consider is T55 fronts (which I also tested). That being said I chose the B25's with a sub because I preferred this bass sound overall.
Good Luck
post #2238 of 4581
So figured the PSB experts could help out with a dilemma I'm having... found an excellent price on a set of the new Image series but just trying to decide what setup to go with. For about the same price I could go with the T5 main, C5 center, and S5 surround (my original preference) or alternatively the T6 main, C5 center, and B5 for surround. This is for a 5.1 setup with an SVS PB10 sub in a 13x15 basement rec room used mostly for TV/movies. My debate is mostly on which surround to go with, I currently have a compact monitor for surround (on stands to either side of the couch directly against the back wall) but have always wanted to go with a bipolar surround; just not sure if it is worth it vs going with the bigger main. Any thoughts/input would be appreciated.
Anyone else have thoughts on my setup based on the new Image series? As of now I'm thinking about spending the extra $300 to move up to the T6, this will be my last speaker purchase for a while so figured it won't hurt to get the best in the range. My setup would be T6/C5/S5... but any input/thoughts would be appreciated.
post #2239 of 4581
Contrary to the last post I have the T45/C40/B15 with HSU VF2MK3 sub. I am 100% HT. The only music i listen to is the music in movies.
I am very impressed with the setup coming from the Infinity primus 250s i had. Dialogue is very easy to hear, and sound is much more crisp and detailed. I would not got with the 55's and 65's might be too much. My room is 16x17.
Definitely get the HSU sub. I know alot of ppl on here go with SVS but try to call them and ask a question. I tried for 2 days and all i got was a recording to leave a msg. So i went with HSU and never looked back.
Before you buy i would check out saturdayaudio.com they are authorized.
Good luck.
post #2240 of 4581
Brother, I too am struggling with which Image package to pick up.
The C5 is a given.
Surrounds are a personal choice - I lean towards direct radiating surrounds, preferring to believe that sound engineers can record the required "diffuse-ness" of a particular surround environment right into the surround channel information and it can be accurately reproduced by direct radiating speakers (with no added diffusion needed from di/bipole surrounds). But that's just me, and I'm nobody special. I'd likely get the B4's actually (smallish family room, WAF concerns, etc).
Lots of well respected people advocate di/bipole surrounds though so, if you prefer them, by all means get them. Something tells me you'd always be wondering if you didn't get 'em...
Like you, my big question is T5 vs T6. Again, I'm in a smallish living room, so there's no need for the T6, plus it's bigger (WAF again), but there's the draw of having the best in the line... especially since I suspect that it'll be a thousand years before the Finance Committee approves another upgrade. Also, there's enough of a difference in design between the T5 and T6 that I wonder if the T6 is much better. I have a sneaking suspicion it might be, so I'm looking forward to the reviews...
If I was in a basement rec room like you, I'd go T6 all the way!
T6/C5/S5 is my vote for ya.
post #2241 of 4581
I'm not opposed to weight reduction but if teh amplifier section remains unchanged and there is an appreciable weight drop from the same chassis, then something doesn't quite add up and I'll bet you dollars to donughts that the new series will not be nearly as robust in thei rpower output as the olde heaveir units. I'm specifally limiting this discussion to Yamaha. Plewas ekeep it in thi scontext without throwing other exmaples that bears no resemblance to what Yamaha is doing. Yamaha Class A/B amp, 10 lb weight reduction in the same size chaissis doesn't add up.
post #2242 of 4581
Well if you're really worried about this, it's completely off topic for this thread so you might want to take your concern elsewhere... FWIW, the Denon and the Yamaha weight reductions are very similar (non) issues!
post #2243 of 4581
Originally Posted by scyan View Post
It's only going to be temporary as I'm delaminating them all in a couple weeks and refinishing them all in maple veneer probably in a shade thats a mix between mahogany and rosewood. I wanted the maple finished psbs to have the silver face on the speakers They're the only ones with it. I will also buy the black grills instead of the silver ones. Altough the silver grills would look totally incredible on someone that has Black speakers. Ohhh, if anyone wants to trade me black for silver grills, mine are BRAND new
scyan,
I know we're going back a ways, but did you delaminate your speakers and refinish them? I'd love to see the pics!
post #2244 of 4581
The C5 is a given.
Thanks for the input, its appreciated. At this point I think I'm pretty much set on the T6/C5/S5 setup, as you've mentioned I am intrigued by the bipolar surround and based on what I've read here and elsewhere I think they would be a good fit for my room (surrounds are on stands on either side of the couch). I have monitor speakers as surrounds now (Paradigm Titans) and I do notice them more than I should hence my plan to try the bipole.
Similar to you once this upgrade goes down my own Finance Committee (hah) won't be approving any additional speaker expenditures so it would be easier to go with the T6 now vs changing course down the road. They are a bit larger than the T5 and my current mains but I have the space on either side of my TV stand and enough depth so that they can sit about 8" or so away from the front wall so that should work. They will certainly be overkill in my room but so are most of the other setups posted on AVS...
post #2245 of 4581
hi guys, i'm looking to get into some psb image series either t6 or t65, i was wondering what the difference was between the two, and whether or not the t6 was worth the extra money at audioadvisor.com
my room is only about 11x15 so im also wondering if the t6 is overkill vs the t5
thanks
post #2246 of 4581
Which models did you compare side by side to get this kind of evaluation? Better power handling? I don't think so. Equal power handling...yes. Better looking? Definately.
Did you see Sound & Visions frequency resposne curve for the new Image series? The previous generation had a flatter curve. There's a bump at around 17.5 KHZ and S&V mag detected some sibilance in female vocals and symbol smashes. I'm gald you like them better but I'm more leary based of this new design based on what I've read so far.
post #2247 of 4581
Non issues based on your say so or based on credable tests? BTW, I'm not worried..just stating some facts that don't add up. And I'll leave this topioc alone now as its out of place in this thread.
post #2248 of 4581
Vise,
I have one more concern with the T6 - impedance. The last paragraph of the Sound & Vision bench test review reads as follows:
"The impedance curves for the Image series run a little low for a line that’s intended for use with relatively inexpensive electronics. The T6 has a nominal impedance of 5 ohms, drops to a low of 2.7 ohms at 410 Hz, and runs below 4 ohms between 90 Hz and 840 Hz. The C5 and S5 are a little gentler, with a nominal 6 ohms impedance and each dropping below 4 ohms only in a narrow range centered around 220 Hz. Sensitivity with a 1-watt signal at 1 meter is good for all models, though: 89 dB for the T6, 88 dB for the C5, and 87 dB for the S5."
http://www.soundandvisionmag.com/spe...nch-page3.html
I'm running my current setup with an Onkyo 606 receiver and I am concerned that it won't be able to properly drive the T6's considering their impedance characteristics. My concerns may be unfounded - maybe someone else can help me here. I'm not able to upgrade my speakers and my electronics, so I'm probably limited to the T5 for now.
post #2249 of 4581
Yeah that could be an issue for you with the 606. I have an Onkyo 875 setup to bi-amp the mains so not sure if that would be of concern if I get the T6, as far as I can tell the 875 does not have an issue driving lower impedance speakers as long as I keep the volume at a sane level. Unless of course someone more knowledgeable can correct me on this.
Edit: Come to think of it the 875 has a choice between 4 ohm and 6 ohm speakers in the setup menu, I would assume since the minimum impedance on the PSB Image series is 4 ohms I would choose 4 ohms here? Can anyone confirm?
post #2250 of 4581
Question, if I gave you $1200 and said build me a 3.0 bookshelf home theater for an upstairs apt that is 22x15 with high ceilings and you have an Onkyo 707 100W reciever already. You like dark brown wood finish.
Problem is you want to listen to your speakers and buy local rather than taking a chance. Your vendors to pick from are:
PSB
B&W
Paradigm
Energy
KEF
Totem
You want to buy now so waiting for used is not an option.
you like rock music, don't listen to much hiphop, but you'll be playing lotsa DVDs and video games on your 46 plasma.
What would be your first selection and 2nd if they didn't have your first. Please include a general model number.
  Back to Forum: Speakers
