Originally Posted by beaveav
As seen in the Stereophile measurements of the Synchrony One, the woofer/port configuration is pretty complex:
http://stereophile.com/floorloudspea...sb/index4.html
Each woofer/port combo is tuned slightly differently, but in general the ports seem to cover the range from about 30Hz to about 80 or 100Hz. So if you're setting your crossover to your sub at 80Hz, the port plugs will mostly be a non-issue. They will make a small difference in the 80-100 or 120Hz range, but that's about it. There is no right or wrong way here, and nobody will be able to give you advice that works for you and your speakers in your room, so the best thing to do is experiment for yourself with the ports and listen for subtle changes in mid-bass response.
If you follow the advice from above and lower your crossover to 60Hz or so, the ports will have more of an effect. But again, it will come down to experimentation on your part.
Thanks for your input, as well as the respponses from TL5 and jgiddyup. Since I am still getting to know these speakers, I'll rely on testing different configurations over time. The nice thing is that they sound great right now!
Based on your quote, I think you might be eligible for a better number as well.
As I summary, T6-es sound very nice for me, and fit my budget well. I am happy, and my thanks to my dealer and Mr. Barton for making these things to happen for me. Should I have more money, I would look at Synchrony line.
If not, I would simply ask PSB which tweeter (if any) would be the best match from what is available. Then I would replace at least two (if not three) tweeters, namely the fronts. But see that still will be more expensive than stocking up on a tweeter or two, haha.
