Originally Posted by
Brian Fineberg
look great! how are they? stable?
nice clean install....did you screw them to a stud? or use drywall anchors?
I used anchor bolts--the speakers are not that heavy. The mount is very stable on the wall. In addition to the clamps that grip the side of the speaker, I was also able to use a bolt through a hole in the mount bottom plate into the mounting bracket on the bottom of the speaker. I believe it is an M6 bolt. This makes the connection between the mount and the speaker absolutely solid. The mount adjusts horizontally 180 degrees, and about 10 degrees in the vertical plane. The vertical adjustment allows me to aim the speaker directly at the MLP.
I also have Imagine Mini's as DSX Height and rear surround speakers. For the Mini's, I use the PSB mounts that are designed specifically for that speaker. Also highly recommended (but a bit pricey).
