Originally Posted by PR Audio
You can find refurbished or used NAD, Marantz, and others that will handle 4-Ohm loads.
Even though Marantz SR-4001 is not oficially rated at 4-Ohm, just like your old SR-7000 it might; but, don't take my word for it check around, maybe check with Marantz. You can find SR-4001 in the refurbished market for about $330.00 with a 1 yr. Marantz Warranty.
Another alternative is an integrated amp, or combo, from Emotiva (www.emotiva.com). Right now they are between model change, and their stock is not the best. But, they just received a batch of refurbished amps they are selling at excellent price...Check them out at www.emotiva.com
THanks for the Tip. I remember when I bought the speakers (6-7 years ago) I called marantz to find out about the SR-7000 and the 4 ohm load. They told me that even though it wasnt rated for 4 ohms it would handle it, and I never had a problem. I think I will have to contact them again.
I received a second response from Denon regarding the 4 ohm capability and they said that only the 3808ci and thats way out of the price range.
