Originally Posted by
xericmx
Is the jump from the T45 to 55 or even 65 worth the extra money?
Based on your room size I'd say the T65's are overkill, but the T55's would fill it better than the T45's.
xericmx
Should I go with the T45 and then with the $ left over get the C40?
It depends on what you want. Will you be watching movies without a center for three months or more because you got the T55's? If so get the T45's and the C40. But if you don't watch many movies then I'd wait.
xericmx
I don't want to even get the urge to upgrade for many years after this next purchase.
It won't matter what you buy, you'll get the urge. This is not a hobby it's an addiction.
xericmx
Anyone have more experience with these? I remember hearing the B15 and the B25's side by side and it was no contest that the B25's sounded better to me....would I get that same effect if I compared the T45 with the T55? Any help would be appreciated.
I had B25's and you're right, much better than the B15's. I've also hear the tower line and while the T55's are more robust sounding than the T45's, the difference is not as big as with the B25's over the B15's.
Hope some of this helps.
