The cost of the drop amps. Not only have I been there and tried that, but, I even swapped TV's between the PX60 and the other that DO WORK.
-LOL
Since TVGOS firmware occasionally gets updated automatically while the TV is turned off (in addition to the normal Guide data), I suspect that it accidentally erased the existing firmware and there was no way to reload it.
Glad to hear you were able to solve your problem. As I'm cable dependent, I never use this function. When the TV Guide channel on Charter actually had a TV Guide, I did set it up and it would update. Now my TVGNetwork channel is some lame kind of entertainment and/or infomercial channel so it no longer does. Not loss to me, as I have the cable guide. The TVGOS is still there, just doesn't do anything.
You have me curious though about the above statement. Are you saying that the firmware updates through the TV guide channel?? As in Panasonic provides updates to that network? |
No two units are identical. Other than actual color calibration settings, you can easily adjust everything else with one of the MANY calibration discs out there. There is even a free one that's discussed in detail on this website. So if you don't already have one, I would suggest downloading the free one (it's a burnable ISO file) that's available. There were two versions, one for an HD-DVD player and one for a Blu-ray player.
Either one can be burned onto a regular DVD.
