Originally Posted by Russdawg
For me in the room I got these things in I played around and I'm going to leave them crossed at 120. I'd love to tell you what to do with your sub but I cant...I'm not there to hear it etc. Volume and everything where it should be on the sub initially you can always fine tune everything after you find a good spot for it.
Regarding the crossover, anywhere from 100 to 150 will "work". However, 150 will give you the maximum dynamic range that the system is capable of. As the frequency goes up, the need for piston area and excursion goes down (the opposite is true, of course). The Orb system is "optimized" for the 150 hertz crossover. Why does Orb give you (us) the choice? Well, Gary Pelled told me that many receivers do not offer multiple crossover choices. Hence their reco of the Pioneers that do.
One other point: if you really want a seamless front soundstage AND can accommodate it, place the center channel vertically. This is the best way to configure any center that uses dual midranges, and with the Orbs' small size, is very doable in many installations.
