The 10Ts will stun you. They're smooth, natural, and musical in so many ways. Their performance is excellent all around and it's hard to pick one particular feature that stands out, but I'll say this: Their bass response will floor you. They're essentially flat to 21 Hz and will easily outperform MANY dedicated subwoofers. However they won't overpower you. They don't have EXTRA bass, they just have all that they SHOULD and it goes pretty near all the way down. They play lower than many subwoofers do.
Amps...I'm partial to Krells, myself. A pair of KMA-160 monoblocks drives my 10Ts and though these are rated at "only" 160 watts pure class A (it's actually more like 250), I've
NEVER run out of headroom.
Given a choice between Brystons and Krells in the same power range and at the same
price, I'd take the Krells every time. But Brystons are excellent amps in their own right and
deserve no criticism from anyone. You can't go wrong with either brand.
CJ
CJ
and listen to the B&W 802D with their HTM2D center channel.
