Originally Posted by sdspga
How are you guys maintaining tension across the top of the screen? It seems that as long as you keep that tight, the wrinkles across the rest of the screen should be minimal.
Steve,
would love to see your setup. I live just behind Lifetime Fitness East of Randall Road.
thanks,
scott
Steve,
thanks,
scott
Back in my more youthful days (last year), I used to go to that LifeTime Fitness (I also lived on the south side of Crystal Lake at that time--we have since moved to the north side, and I rarely venture down that way anymore, except to use the drive through Starbucks when I have my three kids in the car...)
Anyway, back to the discussion. My screen is tensed by a rope across the top of the screen, and sits within a hem on my screen. The rope slides through two large eyelets that sit on the top of my two poles. The rope then comes down at about 45 deg., wraps around a hook, and is tied onto itself with a rope ratchet. I can then make it very, very tight, and it holds the screen up very nicely. However, the weight of the screen, and the rope across the top tend to make the poles on either side to bow ever so slightly inwards, so I have ropes attached to the poles themselves, coming down at 45 deg. and tied off on my fence (although I could probably use rope ratchets here, as well.
Any wrinkles tend to pretty much disappear with this set up, especially when the movie gets started--you don't notice a single wrinkle (or for that matter, stain on the screen, caused by me trying to steam iron the canvas--the iron sprayed out steam that then stained the screen--doh!)
In essence, the screen is like a drum--very tight, and very secure. sdspga--When we finally get things up and running (stupid weather...), I'll pass along an invite, and you can come and check it out. (There's another forum member from Woodstock who wants to come out and check it out as well).
