Upgrading internal drive on the 775D.
Thought I'd share my experience.
Like many I filled up the 160 GB drive and looked for an alternative. Saw a couple of entries here referring to upgrading the internal drive. Here's what I did.
I had a Seagate 1 TB drive kicking around and decided to try and install it in the DVR. The drive was used on a PC and was formatted for NTFS.
I opened up the 775D, removed the old drive, and slid the new drive in.
Once I started the DVR up, it didn't know how to deal with the drive. The DVR diagnostics didn't recognize the drive. Likely because the drive was formatted in NTFS.
I figured I needed to get the drive formatted in the correct format. The problem was how to do this. I could have put the drive in an external eSata case and let the DVR format the drive there. This meant having the case available. I didn't. I got a little creative and put the sata cable for the internal drive into the connector for the external eSata drive. Powered up the DVR. It saw the drive as external and asked if I wanted to format it. I responded Yes and off it went. Shortly I had the drive formatted correctly. I disconnected power and put the sata cables back the way they were.
Once the drive was formatted and the sata cables were back to the original configuration, I powered up the DVR again. It did show a screen saying it was formatting the internal drive again. I'm guessing there must be something specific to an internal drive formatting the external drive doesn't have. Once it finished the second formatting the DVR went through its normal startup tests/configuration and everything came up perfectly.
I took another look at the diagnostic screen and the DVR had correctly identified the drive (manufacturer, model, and capacity).
So far so good. Started recording shows. 1 movie and a half hour show take up about 1%.
