Linden,
Ok, I had another "event." Last night I went into VOD. It was odd, because when I went in, there wasn't the usual annoying VOD sound. Everything was working fine before that. Nothing else unusual happened. Went in and chose a movie, and the video went blank. So I backed out, and could still see the graphics. But could not get in and view video. So went back to regular channels, but couldn't get any video--not on HDMI, component or composite. I could see all of the TV Guide channel info and graphics, but no video or audio anywhere. Click on a program, and it was blank. So I had to reboot the box, and went to bed. Today,when I checked, I had lost many of my HD movies again (not all). And I had checked each to make sure they were playable right after I recorded them. And I had just finished watching a recorded HD movie, and deleted it (Fifth Element) before the VOD episode. The % used in the dvr has dropped considerably down after reboot, and the movies just come up with the delete button when I go to play them. But everything else works fine. So here's the diagnostic info you asked for.
Originally Posted by
lindend
On the PVR status page, below the disk statistics, there are a number of status fields. Please post the values for these fields.
Note: many of the fields are not initially visible and you'll need to hit the down arrow to scroll down.
For the list of items beginning with the # Check Disk Failures, all of the entries are "0" except for the Total Overflows Seen, which is 29.
lindend
I've seen reports of analog recordings having playback issue, but not an HD movie being unplayable or becoming unplayable.
1. If/when this ever happens again for an HD recording, please post all the details from the content listing page.
There's a lot of info for all of the different programs. I'll give you the info from one of the HD movies that I lost and one that I didn't. If you want more, if you send me an email or PM, I'll get the info to you. No need to clog the forum up with this, I'll hold on to all of the recordings until you tell me that you have all of the info you need to help figure out what's going on.
What I did note is that for each of the movies that was lost (I lost three movies out of 5), the MPEG file size in brackets is {0}. For the ones I didn't lose, the size is equal to the MPEG File Size. Also, the three lost movies all had the same L+F state flag: unknown, while all the other programs didn't have that.
This movie was lost:
Application data:
Waterworld
Metadata file size: 5624
MPEG file size: 13174308864 {0}
Trick File Size: 7289184 {7289184}
Clean Termination: Yes
Analog encoding: No
Content type: HD
Recording started at: 12/25/2006 02:00:12
Recording ended at: 12/25/2006 04:30:09
Play Time: 2:29:57
Digital Copy Permit: CCI_COPY_PERMITTED
Analog Copy Pemit: None
Broadcast Flag: No
Recording Overflows: 0
Recorded with build: 001-600-04-15-02-03
Discontinuities: 0
Avg. Bit Rate: 11714400
Disk full pauses: 0
Audio type: Dolby_Digital
Video type: MPEG2
Stream timeouts: 0
Navigation timeouts: 0
Trim offset: 0
Byte offset: 0
Tuner source: 2
Record session time: 8996780
Compact state flag: 0
This one wasn't:
Application data:
Harry Potter/Goblet of Fire
MPEG file size: 13683916800 {13683916800}
Trick File Size: 7846880 {7846880}
Analog encoding: No
Content type: HD
Recording started at: 12/28/2006 22:00:15
Recording ended at: 12/29/2006 00:45:10
Play Time: 2:44:55
Broadcast Flag: No
Discontinuities: 0
Avg. Bit Rate: 11064416
Disk full pauses: 0
Video type: MPEG2
Stream timeouts: 0
Trim offset: 0
Byte offset: 0
Tuner source:
Record session time: 9894630
Compact state flag: 1
L+F state flag: 0
