AVS › AVS Forum › Audio › Speakers › Just get 3 same speakers for Front/Center channel?
post #1 of 25
I'm putting in-walls in on the wall with my plasma and i've only got 10" between studs for the center-channel, so I'm considering just buying 3 of the exact same speaker to use for front right, front left and center channel....i'd just turn the speaker sideways for the center one
will this sound as good as a speaker specified as a 'center channel speaker?'
will i be ok installing it on it's side?
post #2 of 25
Since you will be using in wall speakers, I think getting three of the same model would work fine for you. I have three identical speakers (not in walls) and with one placed horizontal and the left and right placed vertical I notice no problem.
post #3 of 25
IMO it is preferable, but not on its side.
post #4 of 25
3 of the same speaker may be a better choice, as they will be perfectly matched. Don't turn the center one on its side if possible, as the side-to-side and vertical dispersion will be switched.
post #5 of 25
i really need the center one to go sideways; how much will a non-audiophile notice the difference for movies if i go with a regular speaker sideways rather than a center speaker?
post #6 of 25
Do you have any (bookshelf) speakers now? If so, try listening to some music and dialog with it right-side up, then lay it on its side and listen again. Just remember that different speakers have different dispersion patterns, and center channel speakers were designed for horizontal installation.
post #7 of 25
It all comes down to the intellegability of the vocals at different seating positions, you don't need to be an audiophile to not to be able to discern dialogue. I would highly recommend you figure a way to orient the speaker vertically or come up with new plan.
post #8 of 25
ok, i'll do some measuring to see if i can do it normally; it won't look quite as nice vertically as horizontally, but if it makes a big difference in hearing dialogue, then it's not worth it
hopefully i can find an in-wall center-channel that needs <10" mounting hole so I can just use a center-channel; but i haven't had much luck finding one
post #9 of 25
well a normal center will have 2 woofers, right? and if these are 5.25" woofers, then it has to be more than 10" wide, so i'm either gonna have to go with 3.5 or 4" woofers if i use a center channel, which prolly isn't ideal
so i guess i'll have to go with a regular speaker, hopefully vertically
post #10 of 25
And remember that if you are mounting them directly on the wall, don't get speakers with rear ports. Rear ports need at least a few inches room to breathe.
post #11 of 25
...or get three of the (horizontally oriented) center channel speakers. You will be able to fit the Center Channel speaker, and all three will be identical.
Remember, since you are putting these in your wall, you won't have an easy way to fix this if you get it wrong. Identical main speakers are standard practice for good reasons.
post #12 of 25
And none will have uniform horizontal dispersion. That would be worse than one horizontal with the L/R vertical.
Right. That's why he should do the experimenting/evaluating for himself, first.
Kal
post #13 of 25
There's no requirement that it have 2 tiny woofers. One slightly larger woofer will do as well. So, three 2way speakers with 5" woofers, all vertical, might be a solution.
BTW, the use of 2 woofers for center speakers, aside from providing more woofer drive, is a bit of a fraud. It implies a wide dispersion from its appearance while actually offering less uniform dispersion than with a single woofer. (Qualifier: it does depend on the crossover frequency and the inter-speaker distances.)
Kal
post #14 of 25
ok, it looks like my options are:
a) get 3rd speaker that matches l/r speaker and mount horizontally: all 3 match but center is horizontally oriented; i'll try it with bookshelfs tonite to see if i can tell the difference
b) sonance and russound make 9" square speakers; can use a 9" square from them as the center speaker and then the l/rs that i already have: won't have orientation issue but the center and the 2 sides (ultralinear) won't be matched or even from the same company
c) get 3rd that matches other 2 and mount it vertically: i don't think there is space for this, but this would be ideal due to matching speakers and correct orientation
post #15 of 25
Three identical speakers will have identical horizontal directivity.
My point is that three identical speakers will almost always be better than two identical speakers with one non-identical speaker.
I agree fully that most Woofer-Tweeter-Woofer center channel speakers are compromised, bordering on fraud (or just laziness on the part of the designers or marketers). Few companies make a T-W-W center channel - M&K is one - designed to give appropriate directivity.
post #16 of 25
Yes. All will have the same poor and irregular horizontal radiation pattern.
Not if you make them identical by making them perform less well.
Wrong. Unless some sophisticated electronic phase control is incorporated or unless the crossover frequency wavelength is less than half the T-W spacing, the horizontal radiation pattern is compromised. Notice that virtually no well-designed main speaker has drivers placed lateral to each other; they are all stacked!
Kal
post #17 of 25
I have not heard these, so this is not a recommendation: http://www.onecall.com/ProductDetail...31758&id=31763
Physically, 3 of these should work. Has anyone heard them?
post #18 of 25
I haven't heard these particular speakers, but dual-concentric inwalls might be the ticket - if, like any speaker, they pass your audition.
post #19 of 25
Nicholas,
When you line up drivers on a speaker, you get cancellation in the direction that the drivers are aligned and wide dispersion perpendicular to that.
So, if you place a typical speaker sideways, you'll get cancellation horizontally off axis and wide vertical dispersion. If you're sitting directly in front of the speaker, you'll hear it fine. But anyone sitting to either side of you on the couch will not hear it so well. Not good. The wide vertical dispersion means that you'll get reflections off the floor and ceiling, muddying up the sound. Not good. So it's a lose-lose situation.
Placing the same speaker upright will give you cancellations vertically and wide dispersion horizontially. That means that everyone spread out on the couch will hear the dialogue almost as well as the person sitting in the sweet spot. This is good. The narrow vertical dispersion means that you'll get less reflections off the floor and ceiling, making the overall sound clearer. This is also good. A win-win situation.
How you mount your centre speaker is up to you and, unfortunately, based on constraints you have to take into account. However, based on the above, I hope you can understand why Eric, Kal and others are urging you to place it vertically (if you can).
Good Luck,
Sanjay
post #20 of 25
Eric,
Yes. I use seven Kef UniQ bookshelf speakers in my system. When shopping for them, I got several opportunities to hear Kef's CI (custom install) line. There were two things that really suprised me about these speakers: 1- imaging was terrific (most in-walls barely image, let alone well), and 2- there was very little tonal change off-axis (handy when you can't aim the speakers).
Sanjay
post #21 of 25
Originally Posted by sdurani
Eric, Yes. I use seven Kef UniQ bookshelf speakers in my system. When shopping for them, I got several opportunities to hear Kef's CI (custom install) line. There were two things that really suprised me about these speakers: 1- imaging was terrific (most in-walls barely image, let alone well), and 2- there was very little tonal change off-axis (handy when you can't aim the speakers).
Sanjay
Certainly seems worthy of consideration/audition.
post #22 of 25
Doesn't Nicholas have L/R in-walls already?
Sanjay
post #23 of 25
If so, I missed it. Sorry Nicholas.
post #24 of 25
i have l/r in-walls, but haven't installed them yet
i ordered a center and l/r in-walls from a website that said the center was 9.75" long...turns out that was a typo and it's 14.75" so i'm examining my options
it seems like ordering another pair of the l/r and using one of those vertically for the center is my best option; i'm not sure how it'll look tho to have a vertically mounted one under the plasma instead of horizontal, but i don't want to have any sound issues where people on the sides of the couch don't hear the dialogue properly
and since i can't test out these speakers before installing them, i don't get a chance to redo if it sounds poor horizontally
the square speaker is another idea, but my fiance thinks they are too big; i think she'd like vertical more so i'll prolly do that; i did measure and i do have the space to mount it vertically; i'll just google for pics of a setup with vertical center channel under plasma to get an idea of the look for her
post #25 of 25
Check out the user galleries here on AVS. Just click the PHOTO GALLERY link at the top of every page.
  Back to Forum: Speakers
This thread is locked
