Originally Posted by Sarcoma
I decided the easiest way to implement CW_EPG would be to place it in the folder with MyHDAuto. I made the appropriate name change for MyHD.exe and copied the new version of MyHD.exe to the MyHD folder. Now I was ready to rock!
I started CW_EPG and immediately got this error message:
The ONLY file from MyHDAuto that is compatible with CW_EPG is the "Watchlist.csv" file. Using the "ch_maps.txt" from MyHDAuto will cause you problems, so unfortunately you have to delete it and re-map.
Are you using the "-640" command line switch???
The only known problem I've had was using this switch. The first time would cause an error, but then it is fine after that initial acknowledgement.
2. Zap2It allows you to have multiple lineups. In my case I have one for DISH Satellite Programming and one for the antenna. The program that was used in conjunction with MyHDAuto allowed you to choose which lineup to download (although based on time, I believe it downloaded both lineups but only saved one). CW_EPG uses all lineups by default. This caused VERY slow operation until I figured out that I had an extra couple hundred channels that CW_EPG was trying to manage. It would be helpful if CW_EPG allowed us to choose which lineup to use.
CW_EPG processes ALL channels that you defined in your Zap2It! setup. That is why there is this warning in the Readme file:
"NOTE: The more channels you select, the longer it will take to process the guide data. It is HIGHLY recommended to select only the channels that you actually wish to record for display in MyHDs' OSD EPG."
