Nani, I think that the step you're missing is to get CW_Helper's channel lists updated after you've rescanned the HDHR tuner channels and before you try to remap them in CW_EPG. Here's one way to do that:
1. Perform HDHR channel scan in SiliconDust's setup utility.
2. Reboot the PC on which the SiliconDust (and CWHelper) sw is running.
3. Run CW_EPG and then you'll see the updated HDHR channels in the central (unmapped) tuner channels list in the Options window.
4. At this point you can perform the remapping after either deleting individual channels or deleting and remapping whole tuners.
P.S.: Just forget about "CW_Helper commands", please.
