AVS › AVS Forum › Video Components › Home Theater Computers › boot up to full MyHD, with MyIRC
post #1 of 17
...I seem to lack some very basic PC skill...I can drag MyIRC into startup, and all's well, but when I also drag MyHD (program) into startup as well, MyIRC is in-operative. Any tricks for one-step auto boot to MyHD with MyIRC control?
I'm using MDP-120 with an old P3 500, BX440 motherboard, 512 MB ram
...I just want to turn on my computer and end up in MyHD, with full MyIRC control....one step
If I close MyHD and reload it, MyIRC is fine
post #2 of 17
Try putting MyHD below MyIRC (drag and drop works)
post #3 of 17
"Try putting MyHD below MyIRC (drag and drop works) "
tried that ....both ways
post #4 of 17
hmm. Up until recently I had MyHD startup that way. Since I added the playlist manager I don't do it anymore since PLM needs to run first. There is a way to run all the stuff in sequence but for the life of me I don't remember. If it bugged me a bit more I would look into it. Pretty sure it is not complicated. For now I just hit the power button on the remote to start myhd. If not one offers a solution I will look into it further and mention it here. I did like when it all started up.
post #5 of 17
I'm not sure that you can force the execution order in the Startup folder. This may not work either if MyIRC needs a specific head start time and I can't test it right now, but did you try putting them both in a batch file with MyIRC.exe first and executing that from Startup? Such as:
@echo off
REM batch file (MyHD_onestep.bat) to be run from Startup group
START /B "C:\\Program files\\MyHD\\MyIRC.exe"
START "C:\\Program files\\MyHD\\MyHD.exe"
EXIT
post #6 of 17
I kept trying CALL in my batch files but PLM never had time to finish. I will try START and see if my problem is solved. Hope it helps artworkvideo
post #7 of 17
Tell rbatch file to wait/pause between executions.
post #8 of 17
OK, how? (Remember that the goal was NO keypresses required, so PAUSE is off the table)
I think that a fixed-interval pause will require a non Windows utility to be used, but I don't remember for sure if I have ever used such a utility or what it was called. I expect a google or two would turn it up. If it were my problem that would be my next step.
post #9 of 17
@echo off
EXIT
...tried your .bat file (above) and dragged it into Startup...neither MyIRC or MyHD started, and CMD window did not close...thanks for trying
...still looking (sigh...on my Amiga, I would start each program from the startup-sequence, with wait commands...easy text fix)
post #10 of 17
So you've described what didn't happen...what did happen? Any error messages?
post #11 of 17
Ah! The penny dropped. I forgot (again) that the window title is not optional in a START command. The batch file should read:
@echo off
START "" /B "C:\\Program files\\MyHD\\MyIRC.exe"
START "" "C:\\Program files\\MyHD\\MyHD.exe"
EXIT
post #12 of 17
@echo off
EXIT
..SUCCESS...both programs work as they should, without any help other than your script...CMD window closes as well!
Art
post #13 of 17
I will try this when I am home since I had the same problem (batch worked fine but window remained open). Of course now I need to also run "Cliff" and populate my epg.
post #14 of 17
...this is really bizzare. The script worked fine yesterday, but today, the MyIRC program does NOT work until I shut down MyHD and restart, as before???
...is there any way to count to 1 million between the IRC and the MyHD commands?
post #15 of 17
Update 1: ...retrofitted back to V1.65.2...now it seems to work again, go figure?
Maybe it's the Serial IRC and the MPD-120 being a little older?
Update 2: ...removed script and replaced with the MyIRC and MyHD links...all works just fine. There must be something different with V1.66e, which was the version I was using when I started down this road.
Art
post #16 of 17
If you want to go back to 1.66 and explore this, you can see if it's the timing by inserting a PAUSE command between the two START lines. That won't be a good solution for you, since you don't want to enter any keystrokes, but it will confirm that the problem is lack of a delay between the two.
If it turns out that that is the problem, Google for some delay batch file utilities--I'm sure that there are bunches of them. There's a kluged method shown here, for example.
post #17 of 17
..it's possible that this thread is moot...seems that I only have the problem when my virus program (AVS) updates on bootup..first time...I'm back to 1.66e and the two icons only, and things are fine on subsequent re-boots after AVG virus updates.
But Iv'e been fooled before..stay tuned.
This thread is locked
