AVS › AVS Forum › Video Components › Home Theater Computers › Fusion5 "RT" Gold PCI mini review
post #1 of 53
I've found that there's a lack of HDTV tuner card reviews, so hopefully this might help someone looking into building an HTPC with an OTA HDTV card.
I've spent maybe 3-4 months researching, and about the last 2 months putting together the parts, installing software, and testing my HTPC. I actually started with the regular Fusion 5 Gold card a month ago, but I returned it and gotten the RT, so I have a little experience with both.
Spec-wise both cards are nearly identical. The only difference is that the RT card provides a jumper to switch between "SW" and "PME" mode (more on this later) as well front panel pass thru connector for the power switch. Also the regular version of the card comes with a USB IR receiver, whereas the RT receiver plugs into the a/v dongle which plugs into the back of the card itself. The remote itself is the same.
System Setup:
Intel P4 Prescott 3.0E
Asus P4P800 SE
1GB of Corsair ValueSelect (dual channel)
XFX Geforce 6600GT (drv 81.89 winxpmce)
Hauppauge WinTV PVR-150 (1045 non-mce)
FusionHDTV 5 RT Gold Plus PCI (drv 3.30.01)
Windows XP MCE (with SP2, RU2, and lated winupdates as of 2006-03-24)
Purevideo 1.02-196
Installation:
This is a long story, so I'll skip to the chase. I've installed the OS and the card well over 20 times it seems. Initially, all was fine and the fusion card worked well with its own FusionHDTV software as well as MCE 2005. But I had ALOT of stability problems. The system would crash or hang spontaneously. Sometimes when launching MCE, sometimes when switching channels, often the system will freeze while "shutting down". Note that most of the problems occur while running the MCE app, but I've also experienced crashing with the FusionHDTV app while changing channels or even autoscanning channels. I browsed through forum after forum, thread after thread, tech support, etc. I learned the following:
1. Fusion card does not like sharing IRQs, especially with the graphics card
2. Certain drivers, tuner, sound, vid card, may have problems with Hyper Threading
3. Dvico recommends setting the HAL from "ACPI Multiprocessor PC" to "Advanced Configuration and Power Interface (ACPI) PC". This would in fact disable windows from using virtual IRQs 16 and above. But this would also increase the chances of #1 happening.
4. MCE seems to be confused with the analog tuner on the Fusion card and on the Hauppauge card. Recommended to disable the "Crossbar" driver, and in more extreme cases disable the "WDM Tuner" driver. Doing the latter will also prevent those pesky "TV Tuner Malfunction" messages from appearing in the application event log, but will also prevent the FusionHDTV software from working entirely.
In the end, I ended up spending alot of time swapping PCI slots trying to isolatethe Fusion card with its own IRQ, ultimately removing my SB Audigy card altogether and using the on board sound. I also disabled HT, reinstalled MCE 2005 while forcing the HAL to the lower ACPI, and disabled the Crossbar driver. System is 95% stable now, although occasionally when switching channels, I experience a reception hiccup (drops below 70%), MCE will freeze. I then have to kill the process with task manager, and manually kill the ehRecvr.exe.
RT Functionality?:
On the card, there's a jumper to switch between "SW" and "PME" modes. Both of these options basically allow the Fusion card to power on your PC when its off. "PME" stands for Power Management Event, and just requires a compatible motherboard (any semi modern mobo will do) and "Wake on PCI devices" set to enabled in the bios. "SW" is a hardware workaround where you plug your case's the front panel power switch cable to the card, then a provided 2 pin cable from the card to the motherboard. Why does the card need to power on the system? Well remember that the remote control receiver is now connected to the card itself and instead of a USB port. You basically achieve the same with the regular fusion card if you enabled the +5vsb jumper on the motherboard for the usb port connected to the IR receiver.
The fusion card may also be able to power on the system on a timer when used with the Titan EPG, but thats conjecture because I didn't test it. I only wanted to use MCE 2005 for its WAF user friendliness.
Operation:
I'll agree with what most Fusion users generally say, in that, when the card works, its great. I've been able to power on and off the system from the remote. I would launch MCE, watch TV, record shows. I've put the system in standby, and it would automatically wake up and record shows on schedule. Picture quality is great and signal strength is generally strong.
I still suffer the occasional crash in MCE. The weird part is that mce would crash, and I'd hit some buttons on the remote, but nothing registers. I then reboot, and as soon as I log back into windows, those buttons I pressed were somehow queued and they start to register, doing stuff like launching applications and navigating menus.
Another quirk I've found: I disable the WDM tuner to see if that if that would fix my stablity issues, but soon found that doing that would also disable the remote control. I guess that that must be the device/driver that controls the IR receiver which now that it plugs into the card.
Conclusion:
All in all, the card works great and I'm satisfied with it. When it works, it works well. I keep complaining about crashes, but they are not as frequent as it would seem; realistically more like once or twice a week.
The RT version of the card doesn't really offer anything over the regular version. in retrospect, I think I would have preferred the regular version for the usb IR receiver. That way I can disable the WDM tuner to see if that made a difference. And the remote would still be functional even if the card has hung. The RT's IR receiver is alot smaller and easier to hide however.
Installation is a headache, but I hope this review may help some people with similar issues. My biggest gripe is disabling HT, which judging from past cpu comparisons accounts for a 10-15% boost in system performance (at least in thread-aware applications). Hopefully driver updates would soon remedy this.
MCE 2005 wasn't intended to be installed by the end user, and there are gotchas at every corner. As forum user Cgsheen summed it up well, "the biggest reason I've had such success with all my FusionHDTV tuners is: I built my HTPC's around them. I used only "known good" hardware and software whenever and wherever possible."
In the end, it works, and it's currently undergoing the WAF test trial period, but looks like it will pass, so all is good.
For anyone building an HTPC, consider using Symantec Ghost or Acronis True Image. I can't imagine how much time I would have lost/wasted if I had to reinstalled windows from ground up every time I wanted a fresh start.
post #2 of 53
About to buy this card....one thing I can't figure out though....what "extension" does it capture in? Is it .avi, or .mpg? I'm curious because it seems like Premiere, at least for me anyway, works best with raw .avi files.
post #3 of 53
Excellent review!
I am also about to order the Fusion5-RT Lite to go along with my Fusion5 Gold. Just want to get the ability to record 2 HDTV programs at once and also the ability to record 1 OTA and 1 QAM. I can currently do either or because of obvious reasons.
I am also upgrading/adding the HDD capacity w/ 2 more 250GB drives that way I have the added room.
Overall I have only 1 issue with the Fusion and that's the constant releases of drivers that just fix a few things and but still have the few bugs.
The latest drivers have been pretty stable so my agida is calming down ..lol.
post #4 of 53
Royal--
Unless you're planning to put the two Fusion cards in separate PCs, you'll have trouble with your goal of recording OTA and QAM at the same time because the current Fusion sw can't chew OTA gum and walk QAM at the same time. It controls 2 or more tuner cards but they won't reliably work on different input types at once. A better single-PC solution for QAM+OTA is to have a MyHD MDP-130 and a FusionHDTV card. They can be set to record completely independent of one another and suffer no interferences.
fierygt--
In case you never found out the answer to your question, it's "neither of the above". The Fusion cards, like all the other HDTV tuner cards, capture DTV in their native transport stream form, which is an encapsulated MPEG-2 format that's designed for lossy transmission, such as OTA TV broadcasting. FusionHDTV also has an option to save to MPEG program stream (.mpg) but it's buggy and to be avoided, since it saves no HDD space and is generally less compatible with non-FusionHDTV HDTV players.
post #5 of 53
orangecream, thanks for your great review! It's very helpful!
One quesiton:
Im planning to buy a Dvico FusionHDTV5 PCI gold, but a little bit hesitating on selection of RT version or regular version. From the review, I knew that the RT version has a switch which can select between "SW" and "PME" mode. What about the regular verion? I mean wether the regular version has only one mode? If yes, which mode is it? If the regular version has PME mode, I'd buy the regular verion since I like the USB receiver. If the regular version has SW mode only, I have to take the RT version, since I will be installing the card into a Dell desktop computer, the power cable connecting the motherboard and case is patented and not as same as other self-made PC.
Any inputs will be appreciated.
post #6 of 53
I also have a Fusion 5 RT gold. I now have the RT gold and a regular Fusion 5 I've been using for a year already. Before, I previously only had the analog card to setup everything and then I yanked it out, but with my need for dual tuners, i bought the RT gold . I currently do have the analog (avermedia) card still in but once I installed the second Fusion card, the lag problems started for me also. Previously with only the Fusion card in my rig, I had no lag problems.
Disabling the crossbar did fix the problem, but I do experience occasional crashes in MCE more often with 2 HDTV cards than with 1.
post #7 of 53
I'm looking for card that will allow me to watch and record HDTV AND analog TV, via XP MCE. Would this card do that?
post #8 of 53
I need some advice please.. I have a Beyond TV installation with a Fusion HDTV5 lite card that work(ed) just fine with the one card. Now I am trying to install a second HDTV 5 lite tuner card and have LOTS of problems. I am getting several different symptoms:
1) I get error message: EP31 Hardware Error, Connect pin to filter failed, please reboot the PC.
2) Another says something about the crossbar failed.
3) I cannot get any TV pictures or sound on the second card. But the card works OK if I use it as card #1 all alone without a second card installed.
4) When the second card is installed I get a 'new hardware found' indication at boot time, but the (supposed) USB driver cannot be found.
I figure I have some sort of resource conflict.
What I have: ASUS P4S800D-X MB, Nvida GeForce 6200, Fusion tuner cards, 1GB RAM. Freshly downloaded drivers from Divico Fusion, Nvida, and Beyond TV.
But I cannot even get the FUSION software to work on the second card when it is installed. First card works fine.
All suggestions/hints/help will be much appreciated!
post #9 of 53
No. None of the HDTV tuner cards by themselves work with MCE. You need to have a tuner card with a hardware MPEG-2 encoder (read: NTSC tuner card) in addition to the HDTV card to make MCE happy. Some have reported success with removing the NTSC card after configuring MCE. However, that applies only to ATSC operation, not analog.
post #10 of 53
Make sure that your AGP aperture setting in BIOS is at least as large as the DRAM size of you nVidia card.
post #11 of 53
word has it that the latest rollup removed that requirement....
post #12 of 53
...and have you tested this, Jim? AIUI, your experience with MCE and a different ATSC card involved a machine that had an MCE-recognized analog tuner, no?
post #13 of 53
what fusion app version are you using? i ran into the ep31 error using 3.41 web and posted here:
http://www.avsforum.com/avs-vb/showt...&&#post7967175
there were a couple other posts about the problem before and after my post. i have since moved to fusion app version 3.42web and not had any more ep31 problems. i think ep31 is a one time error that comes from the fusion app thinking it has multiple tuners and getting mixed up about which tuner is doing what. i couldn't reproduce the error to track it down. i removed and re-installed the fusion app afterwards.
post #14 of 53
My EP41 error was also in Fusion software version 3.41. I was not even able to get an install on both Fusion cards with the fusion software from the package CD. This error message comes up every time I start up the Fusion program IF the two cards are installed.
Do you guys recommend I get some other card for the regular cable TV sigs (A few of my cable channels are already HDTV but I get most via OTH.)? I was hoping to have two HDTV cards so when both Cable and OTA TV move to HDTV, I would be already set.
I first bought a Sapphire 9550 video card but it causes reboots and will not operate in dual desktop mode so I am sending it back for exchange. I think it is just defective. I am temporarily using a Nvida 6200. What video card do you guys think is the BEST one for HDTV use? I would like to have a HDMI output, but DVI is about all that is available just now. And it works GOOD!
post #15 of 53
EP41 error is not specific to 3.41. that error is an indication you have not gotten a good install of hardware or software/drivers.
here's a link to a proven process to get the software removed/installed:
http://www.avsforum.com/avs-vb/showt...&&#post7600356
post #16 of 53
I just got the following reply from Fusion Tech Support:
Basically: They say that>
1) Some Mother Boards (such as the ASUS P4S800D-X) have interrupt problems when more than one HDTV5 LITE card is used in a system.
2) Their HDTV5 GOLD does not have such problems.
I have asked for a list of motherboards KNOWN to work with their more than one of their Fusion HDTV5 LITE cards but have not yet received any reply.
They also said that they take no responsibility if their cards do not work in any particular MB but that they will try to test it in a P4S800D-X MB.
Is there another HDTV tuner card that is known NOT to have such problems?
post #17 of 53
Hello there,
I 'm looking for a PCI HDTV tuner card (If theres PCIE cards I'd prefer that).
I was looking at ATI HDTV Wonder until I found this thread about Fusion cards.
My current system is;
Asus K8v Deluxe
Athlon 64 3200
1 GB RAM
250 GB HD
Geforce 5900 FX with 128 MB
Onboard sound
Your ideas will be very welcome
post #18 of 53
Anybody can kindly answer my question? Thanks in advance.
Originally Posted by old-cotton View Post
I'm planning to buy a Dvico FusionHDTV5 PCI gold, but a little bit hesitating on selection of RT version or regular version. From the review in the original post, I knew that the RT version has a switch which can select between "SW" and "PME" mode. What about the regular verion? I mean wether the regular version has only one mode? If yes, which mode is it? If the regular version has PME mode, I'd buy the regular verion since I like the USB receiver. If the regular version has SW mode only, I have to take the RT version, since I will be installing the card into a Dell desktop computer, the power cable connecting the motherboard and case is patented and not as same as other self-made PC.
post #19 of 53
Anybody can answer this question? Help please.
post #20 of 53
The non-RT Fusion cards are all effectively "PME" mode.
post #21 of 53
Thank you very much, TPeterson! Your input are very helpful. I decided to go with the non-RT version. Thanks again and have a great day!
post #22 of 53
I would be very interested in this card if it recorded QAM (it says it does on the site, but I have a feeling it is only with their software and not with MCE) from a digital cable source. I know currently my cable is unencrypted and I would love to be able to get rid of my STB if that were the case (the SA8300HDs are total junk).
Kage
post #23 of 53
Does it record QAM in MCE?
No, but it does record clear QAM very well using the vendor's sw. If the content you're interested in is scrambled, however, you'll not be able to record it with either sw.
post #24 of 53
Thanks for the quick reply. That sucks. Does any hardware do that in MCE or is that a limitation on MS's part?
Kage
post #25 of 53
This is still true. I tested myself with a fresh MCE, downloaded all updates and when I tried to install only a ATSC tuner got the "requires analog tuner" message. The person who said an analog tuner is no longer required probably had one originally and then removed it.
post #26 of 53
I thought rollup 2 removed that requirement?
post #27 of 53
You thought wrong.
post #28 of 53
No, but Vista removed that requirement for sure (doesn't help right now, I know, but nice to know the next version removes that "feature").
Kage
post #29 of 53
Further info on my attempt to use two Fusion HDTV5 LITE cards with Beyond TV and a ASUS P4S800D-X motherboard. Divico now says that running TWO HDTV5 LITE cards on a motherboard with OTHER THAN INTEL chipsets can be a problem because the interrupts may not be handled correctly. Divico now recommends using the Fusion HDTV5 GOLD cards whenever you have a MB with a non-Intel chipset. The ASUS P4S800D-x MB does NOT have an Intel chipset.
So far this information is not listed on either the Divico FAQ list nor is it on the Beyond TV website. Believe me, you can waste a tremendous amount of time trying to get a pair of the HDTV5 LITE cards working together on a non-Intel MB.
post #30 of 53
I have had my FusionHDTV 5 RT Gold for a few months now but just got around to using the "RT" Real Time clock feature of the card. I am using it in a computer that does not have PME so I used the jumper cable to wire the Fusion to the power switch connector on the motherboard and the power switch cable connects to the Fusion. If I schedule a recording and then turn off the computer the RT Gold will actually start the computer 5 minutes before the recording is scheduled to start. This works from a "complete" power off state, not suspend or hibernate. I am using the shutdown command to turn off the computer after Record_This runs in the early am. Also, the remote control can be used to turn on the computer from the power off state. Now I am not too sure if I will actually be using this feature since we watch our recorded shows from 5pm to 8pm each evening so the computer is on in time for recordings anyway. I just thought it was pretty cool that it turned on the computer from a power off state.
