Well, another update...
I put the lamp cover door back on, making sure that it made good and consistent contact with the safety switch (tried wiggling/tapping it after installation to see if I could make the yellow LED come on (on the front of the TV). When I was satisfied, I turned the TV on. It was on for about 5 hours with not one problem.
I monitored the temperature sensors for the first hour or so.
Time Temp1 Temp2
start 32 34
30 mins 44 56
60 mins 45 58
Never saw them get higher than this.
At this point I'm hopeful, that the cleaning (and maybe the mucking around with the safety switch?) has resolved my problem.
Fingers are crossed.
So far, hasn't cost me anything except some time. And I've learned a bunch of things too!!
...Dano
Time Temp1 Temp2
start 32 34
30 mins 44 56
60 mins 45 58
...Dano
Spare light engine to boot, so I'm good for awhile.
