Originally Posted by
Splicer010
Use this stuff but get it as a single can for about $3:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
...along with a microfiber towel. The front bezel needs to be removed to gain mirror access. Clean your light engine lens also while in there as well as the entire cabinet cavity.
Just to clean the mirror, interior cavity and light engine lens is the best suggestion in my opinion.
Today I was cleaning the screen of my 56HM66 and up close I saw what looked like a long strand of hair that was stationary yet moving around on the inside of the screen. This leaves me to believe I need to clean out the entire inside of the set. I have ordered the microtowel and the cleaner. As you mention there are 3 areas of cleaning, the cabinet, the mirror and the light engine.
1) Is access to the interior from the rear of the set ... does the manual have instructions or can I find them somewhere in this thread?
2) Will the placement of the mirror and light engine inside of the set be obvious when I open the set?
3) Can the light engine also be cleaned with the cloth and cleaner?
4) A poster right after your post says the light engine must be remove and to clean?
Like many others, my set was purchased Black Friday 2006. Still on the original bulb and whenever the set has a hiccup (only a couple of times), I just unplug the set. The original bulb probably has over 8,000 hours, however the set has always been in a dark room so the brightness setting has always been turned down and the lamp has always been set to "Low Power" mode. The only complaint would be there is only 2 HDMI inputs as my receiver does not have HDMI switching. This is still my #1 set and I will be going OEM when the bulb pops.
Just a great $1200 investment that resulted in me having to buy many other HD devices over the past 4 years, including two other smaller HD sets (both LCDs), 1 HD-DVD player, 3 Blu Ray Players, WD TV Live Plus, Seagate Home Theater Plus. an XBox 360 that has HDMI out (previous one did not have HDMI) and a laptop that could play and stream HD.
