Based on the quotes below, If I want to use my computer to update the 4306 and say Oppo 83 (it also uses ethernet), and also play music and send pic's and home movies from my computer to the Denon, I need to run both an Ethernet cable and HDMI cable?
Originally Posted by chmilar
Are you just connecting the computer to upgrade the firmware? Or do you want to have the computer's display on your Panasonic?
If you are only upgrading the firmware, then you just need to connect with an ethernet cable. The computer will not display on the Panasonic. It will display on whatever monitor it is currently connected to.
If want the computer to display on the Panasonic, then you need a cable to connect from the computer's video output to one of the 4306's HDMI inputs (or you can also connect the computer directly to an input on the Panasonic). This is not required for a firmware upgrade, but it will let you play video clips from your computer on the Panasonic.
Originally Posted by jjd
That was a very good response chmilar. However, there is no requirement to use just HDMI to send a computer video stream to the 4306. You could also use a composite or S-Video connector if that was what was available from the computer. Of course, a HDMI (presumably via DVI->HDMI converter) would provide better quality output.
) make sure you are really on the 'outs' and not the 'ins'.
I checked no other zone/rec out is connected to that source....
Fortunately, it didn't mess anything up and was successful.
