Originally Posted by willy05008
thanks areyou4real! I thought it was the TV or me. Well I can handle it until Verizon Fios is in my area and I can try taking out some of the splits also. I'll just get some new cable and redo the run to that room. Or I can look at Direct TV/Dish but don't want to really sign on for a year.
Thanks for the help.
This is the Best HDTV Forum, I've learned a lot here and still have a ways to go.
Check your local forums, but your cable provider probably isn't recompressing the signals. Most cable companies just pass through what they get from the local station or satellite. Verizon will be getting the same signal. You're probably seeing the result of multicasting that areyou4real explained very well.
Check out some sports on ESPNHD & ESPN2HD and it will probably look better, it's very likely that these channels are being forwarded as is.
If it's local multicasting you're experiencing then all you can do is complain to the local stations, which usually is unsuccessful.
![Disney WOW: World of Wonder [Blu-ray]](http://cdn.avsforum.com/d/da/50x50px-ZC-dadc69a0_B0045ASBLG-51TziBcqZFL.jpeg)
