Originally Posted by 120inna55
For $200, I'd take it as long as the stuck mirror doesn't bother you. But I wouldn't go any higher than that. Frankly there are things that can be wrong with it that may not be apparent with a few minutes of demonstration. With prolonged use (1 to 2 hours), heat could be a factor and you could start experiencing random shutdowns. Other failures can be so random and intermittent that a single demo wouldn't necessarily reveal them. I think that's why you didn't get an immediate response to your inquiry. It's all about the risk you are willing to take.
Otherwise, I'd listen for whining upon start-up and during play. An initial click and hum and even brief high-pitched whir (1 second duration) is acceptable. That's just the ballast firing up the lamp and the subsequent spin-up of the color wheel. The fans will make some noise, but it shouldn't be distracting. That's all I can think of. Good luck.
Thank you so much for the insight. Very much appreciated.
![Disney WOW: World of Wonder [Blu-ray]](http://cdn.avsforum.com/d/da/50x50px-ZC-dadc69a0_B0045ASBLG-51TziBcqZFL.jpeg)
