AVS › AVS Forum › Display Devices › Rear Projection Units › Samsung 1080p Owner's Thread --- HLSxx87W/HLSxx88W DLP Models
Samsung 1080p Owner's Thread --- HLSxx87W/HLSxx88W DLP Models - Page 97
post #2881 of 21315
Just got my 6188 today. The HD quality is good. The others are not that great. Does anyone know of the basic tweaks I can do to improve on the out of the box settings.
Hello and welcome!
Try these as a good starting point.
Digital NR - OFF
DNIe - Off
Mode - Movie
Contrast - 40
Brightness - 45
Sharpness - 0
Color - 45
Tint - G50/R50
Color Tone - Warm2
Here's a link to a DVE tutorial that Dave Abrams and I wrote that may assist you further.
DVE Tutorial
I received my 6188 from TVA about 2 weeks ago. Have done some of the minor tweeks and setup. Love the set so far overall... I do have one problem: there is a minor distortion visible when watching white and/or bright scenes. This looks like a 4-5 inch stripe of "goop" near the middle of the screen, but it is not on the screen itself, and is not visible in dark scenes or when the set is off. I assmune this means it must be something inside the set that needs to be cleaned or adjusted.
It is definitely not source related (appears when watching HD OTA signlas, SD satellites, DVD and Xbox material) and is not a problem on the screen itself (outisde or inside as far as I can tell.)
So... given this thing is only two weeks old, do I wait to see if I have any more serious problems before calling for service, or get someone in now? And, if anyone has had the insides of one of these cleaned, is that a straight forward operation that can be done without much risk breaking anything else? I love the set overall and this isn't bad enough to risk breaking the whole thing!
Thanks for any feedback,
Mike
Sounds to me like the set's optics need to be cleaned. If it's not on the front screen (lens actually), then perhaps the smudge is on the inside (Fresnel) screen. One easy way for you to check this would be to remove the circular cover on the side which will give you access to the inner cabinet. Then, take a clean microfiber cloth and gently wipe the inner screen where you think the smudge is. You may want to have a friend help guide you. If that still doesn't resolve your issue, try gently wiping the mirror. If that doesn't do it, try very gently wiping the lens. Now if neither of those work, then your problem lies between both outer screens in which case you may want to get an exchange. This was the case on a clients 6187 a couple of weeks ago. We had to remove the entire bezel from the TV, remove the screens from the bezel, take them apart from one another and clean in between. Sure enough, there was a ton of "stuff" trapped between both screens! Then, there was the not to easy task of reversing the process. But I can be a glutton for punishment sometimes.
Eliab
post #2882 of 21315
Where do I get a DVE disk from? Is this from Joe Kane? Any info on this would be great... Thanks!
post #2883 of 21315
ez4me2,
Pretty much any on-line DVD retailer should have it.
Eliab
post #2884 of 21315
Originally Posted by David Abrams View Post
egrady and jhferry,
Interesting questions and observations! Here is a little more information regarding what is happening in the system...
In order to properly evaluate the 1080p capability of the display 1:1 pixel mapping must be achieved. To do this on the Samsung displays the overscan feature in the service menu needs to be toggled to off. Many people are experiencing overscan coming back on when the set is turned off/on which makes it difficult to evaluate 1080p sources accurately. We have not found this to be the case on every model, the Samsung HL-S5088 seems to maintain 1:1 mapping once setup.
In regards to the Samsung Blu-ray player When looking at material from the player it is important to keep in mind that the player actually converts 1080p to 1080i then processes the image back to 1080p through a Faroudja FLI8638 processor. So it goes from 1080p/24 to 1080i/60 to 1080p/60 in the player. The image that ultimately comes out does not have the full resolution of native 1080p.
Heres the part that bugs me though, they didnt just use the samsung player:
the Samsung HL-S5687W couldn't fully resolve every detail of 1080i or 1080p sources onscreen, according to test patterns from our HDTV signal generator (for 1080i) and the resolution chart on Sony Blu-ray discs (1080i and 1080p). It did de-interlace 1080i sources properly
How can you de-interlace a 1080i signal properly but not display it. Unless they are bascially saying that wobulated DLPs do not actually show you the full resolution so to speak. Thats how I took it. Technically, everything is de interlaced but on screen, all the pixels dont make it there. Thats is a big deal If you ask me.
post #2885 of 21315
Start here.
Eliab in User Calibration
Eliab on Using DVE
post #2886 of 21315
Hi all -
I took some pictures of my HL-S6188 last night, if you want to see:
http://files.filefront.com/TVpicszip.../fileinfo.html
The pics are not downsized, so the full zip file is 59mb for 27 pictures.
Enjoy!
post #2887 of 21315
nikolausp,
I'm seeing a darkening across the top and the bottom of your pictures (vignetting) and would like to know if its in the actual TV or in the way it was photographed. I also see some bowing across the bottom which would indicate that you're using a wide angle lens set up fairly close and this might account for the vignetting.
Please clarify.
post #2888 of 21315
Someone recently posted that you can change the screen position of the image by slightly pulling on the set. It works.
My biggest gripe with the set was that the image looked slightly rotated counterclockwise by ~1 degree or so. When watching 2.35 AR movies, the top black bar was narrower on the right side and the bottom black bar was wider on the bottom.
I tried gentlely pulling on the top right hand corner of the set. Lo and behold, the image dropped slightly on the screen. I was able to coax the plastic case enough so that I now have straight edges on both top and bottom black bars. This didn't correct the pincushing, but I can live with that.
I think what might be happening is that because the frame is largely made of plastic, it might get bent slightly during shipping distorting the front screen. I am now very, very happy with the set.
post #2889 of 21315
Originally Posted by JimP View Post
nikolausp,
Please clarify.
Well, there's no way for the pictures to capture it perfectly.... or do it justice. nothing you mentioned is present in real life on the TV... as for the wide-angle... I don't know much about that.... I took the pics with a Canon Powershot G6, in full manual mode, with a 2.8 apeture, and varying shutter speeds to try and get a good light on the pictures... i'd say an average shutter speed was around 1/25 or so.
Amidst the negatives you pointed out, did you see anything you liked?? ;-)
Also note, the car picture is from Project Gotham 3 on the xbox 360... and the wedding picture is from CSI last night over cable via the QAM tuner. The rest of the pics are from DISH Network.
post #2890 of 21315
nikolausp - Good shots. Glad to hear that some came from Dish HD. How is the SD?
post #2891 of 21315
I have Directv and a HD Tivo into my 6187. The 6187 replaces a three year old Hitachi 57" rear projection. The Hitachi was the first HD set other than Elite or Mits. that I thought had a good enough std. def. picture for me to buy. The SD pic varied from very good to very blurry, depending on the signal. The 6187 is no better, and no worse.
post #2892 of 21315
Originally Posted by dlowy View Post
As does Abt Electronics at $2999 with no tax or shipping. They do negotiate.
I just got the 6187 (not the 5687) from Abt for a few hundred less than that. I live in the area and it was in-stock, so two days later I had a TV. I also got the 4-year extended warranty (with bulb replacement).
So far, it's very nice. I did Eliab's set of quick adjustments and the TV looks fantastic (the out of the box was not so nice). I'm just waiting for my Monoprice HDMI cable for the Moto 3412 DVR (using component for now) and Oppo DV-970HD to arrive on Monday today! (Just checked the shipping status.) I may never leave my basement!
post #2893 of 21315
Derf,
Let us know how the Oppo looks on the set-- I'm about ready to bite on this, but worried about the Macroblocking issue. Thanks!
post #2894 of 21315
Which OPPO DVD is best suited for this display? The 971H or 970HD or the new unit they will be releasing in the near future? FYI, The 970HD doesn't have the macroblocking issues, that's specific to the 971H unit which is actually considered the "better" unit.
post #2895 of 21315
I'd like to get rid of the overscan on my HL-S6187w . I'm ok with the color and everything else. I just want to fix the overscan. I've done this myself in the past with several Sony RPTV's and a Toshiba. Would it be that difficult to fix just the overscan myself? - past TV's I've been able to fix the overscan rather easily but I've heard these ones are a little more difficult. Any one have any links or advice on this? Thanks!
P.S. really loving the 1920 x 1200 PC input - looks great - I'm using the display to type this message!
post #2896 of 21315
Any of you HL-S owners without cable or satellite (only OTA) looking for a DVR that is HD?
I am reseaching this and having not having much luck..... The DISH VIP 622 looks like a winner, but it appears it may require DISH activiation.
Again, with simple OTA, what is the best HD DVR out there, as a practical matter?
post #2897 of 21315
I think it's a bit of a toss-up. The 971H is probably a better unit, but unless you feel like doing a lot of tweaking of your set (or paying an ISF guy to do it), the macroblocking problems sound like they are just horrendous on DLPs. The 970HD isn't as good (no Faroudja), but doesn't have the macroblocking problems (because it has no Faroudja).
According to the DVD shootout, the main issues with the 970HD seem to be things that won't affect me very often, if at all, so I'm not really worried. Plus, the 971H became the most highly rated DVD player after several firmware updates - the 970HD, being brand new, hasn't had the firmware polishing (yet), so I'm hopeful it will get even better (a new beta firmware is already out).
post #2898 of 21315
Of course I did.
I like the fact that you went to the effort to provide pictures to the forum.
post #2899 of 21315
On my HLS-5087, when viewing an HD signal with an OTA antenna and the picture set to 16:9, I am getting black bars on the sides. The set says the signal is 1080i and 16:9. Shouldnt the entire screen be filled? What am I doing wrong?
post #2900 of 21315
A more accurate way to improve an image leaning slightly one way or another would be to readjust the DMD module's position.
Glad to hear things are looking better. Take it up another level when you get your 970 by going through a DVE user-level setup.
Not nearly as much of an issue on the 970.
You can't get rid of overscan entirely but can certainly lesson it. My 5088 is set to about 1%. It needs to be done within the service menu. PM me and I'll show you how.
Eliab
post #2901 of 21315
Not necessarily. It can very simply be that particular program that's being broadcast at 1.33:1.
Eliab
post #2902 of 21315
I took delivery of a HL-S5687w a few days ago, out of the box the pq was excellent I was very happy with my purchase. Today I hooked up an htpc and while surfing the net I noticed small spots on the screen. They stand out when there is a white or very light bright background, at first I thought it was a smudge, so I took the supplied cloth and tried to clean them, but no luck. I started to think that maybe there was some dust on the lens, but when the tv is off I can see the spots while looking at an angle but there very faint almost unnoticeable. Even though while watching content the spots aren't noticeable it still bothers me that they are there. Has anyone else experienced this problem or have a solution, I dont want to return the tv if I can fix it myself. Any suggestions will be greatly appreciated, Thanks in advance.
post #2903 of 21315
Any HDTV source will send you a 16x9 image regardless of the aspect ratio of the original material.
Program material created with HDTV cameras will fill your screen exactly. Most of the time the commercials are still SD (4x3, 1.33:1). The HD channels pad the 4x3 (1.33:1) image with black bars, then they send it to you inside a 16x9 image.
HD channels sometimes show SD material. It's treated the same way at the source by adding black bars to each side of the image to create a total image that's 16x9.
When HD channels show movies that are wider than 16x9, like 235:1, they either use black bars top and bottom, or they crop the image. In either case, you will receive a 16x9 image from the source. Your TV is just displaying the 16x9 image that it has received.
post #2904 of 21315
It sounds like there is some dirt on your screen. Since you cleaned the outside, it's probably between the layers or on the inner surface. The dirt might also be on the mirror.
I just read a post by Eliab that gave some instructions for doing the cleaning job yourself. I can't seem to find his post now.
There are access panels that you can remove to get to the interior surface of the screen and the mirror. Use a "micro fiber" cloth to gently clean the spots on the screen. If that doesn't work, clean the mirror gently. If that doesn't work the dirt is probably between the screen layers. That's a mess to do yourself.
If the first two attempts fail you can also gently clean the lens.
Use a clean micro fiber cloth gently.
post #2905 of 21315
Does anybody have HL-S5688W in stock and ready to ship?
post #2906 of 21315
I also am looking for a reasonable price for a ready to ship HLS5687W.
I do not see any... some sites show "In Stock" but when you call and check they really do not have them.
I assume this means Samsung has some issues with at least the 56inch size...
Does anyone know if there are supply or manufacturing issues?
Thanks for any info anyone might have...
post #2907 of 21315
Smudge cleaning tips.
I failed to mention that a good solvent for the mirror/lens would be Pancro Lens cleaner. For the screens I would use Screen Kleen.
Eliab
post #2908 of 21315
I took of the access panel and took a peak inside and there they are a few spots on the back of the screen. They almost look like water spots, I tried to wipe them with a microfiber cloth but no change they look terrible from the inside. I think i have no choice but to call the retailer or samsung, thanks for quick responses
post #2909 of 21315
Eliab
after a tv is calibrated, should all adjustments be left alone? the reason i ask is becouse last night i was switching between two baseball games, both in hd. i like a bright pic. so i leave it set on standard, with contrast, and sharpness turned down. both were night games. i still had to make adjustments between the two channels. it seems as though there is no set standard. i make changes everytime i change channels.
post #2910 of 21315
Sounds like the culprit is between the screens. Definitely a service call thing.
With DVD and true HD material there won't be as much of a varience. With SD broadcast material, however, it's not uncommon for there to be a noticeable disparity from day to day, channel to channel or program to program! So minor user-menu adjustments may need to take place in order to compensate for the inconsistent nature of these sources.
In regards to standards, they have been established by The Society of Motion Pictures and Television Engineers (SMPTE). Unfortunately, most manufacturers and television stations don't always abide by them. But this is precisely what's so special about the current Samsung DLP displays. Once calibrated correctly, they'll abide to SMPTE standards more closely than any other RPTV in the market.
Eliab
  Back to Forum: Rear Projection Units
