AVS › AVS Forum › Display Devices › Rear Projection Units › Samsung 1080p Owner's Thread --- HLSxx87W/HLSxx88W DLP Models
Samsung 1080p Owner's Thread --- HLSxx87W/HLSxx88W DLP Models - Page 261
post #7801 of 21315
Originally Posted by bbchurch View Post
Okay after much debate I finally bit the bullet and got the 56 in samsung 1080 got it home last night loved it until my wife came in the room and said why does the picture look pushed in? I said what are you talking about and she said look from over here it looks dented in the middle. Sure enough when you stand off to the side about 2 foot to the side of the tv and about 5 foot back the picture has a distinct curve to it. I felt of the outer screen and it felt flat so it must be the inner screen or something else inside? Now my wife said she could also see it when looking at it straight. I could not tell for sure if she is nuts or if there really is a problem. Is this a condition any of you seen before or are we just expecting way to much of a "flat" tv. Billy
Originally Posted by pwp View Post
Somebody posted a side-view picture (from the manufacturer) and it's clear that the screen has an inward bow to it.
I saw that screenshot, but I am not 100% convinced that the screen was bowed, nor if it was if that is normal. First off, that looked a lot like a shadow effect of the the bezel. Even if not, I do not think that the screen of the HLS5687w is by design bowed in or out, even a little bit. My set displays no bowing at all, from any angle, and my image is straight and true viewed from side to side and from top to bottom. I do not think that is inherent in this design or in any DLP. If you have this problem I would definitely take it back and exchange it. If nothing else, go to the store and view several DLP sets there at an angle and see if they all exhibit this problem.
post #7802 of 21315
Originally Posted by Tarheel72 View Post
This has been discussed several times in this thread and a search should reveal the postings. The optical output will deliver 5.1 DD for OTA signals received via the ANTENNA input. I can personally verify that fact. It will not output a 5.1 signal for other sources that might be connected via HDMI (with or without the RCA L/R inputs for DVI conversions), component, or VGA.
Sorry,
I did do a search, but all I could find was about HDMI passthrough.
Anyone else notice that their coax inputs feel kind hot? I just noticed this today, so I have no idea if it is normal or not.
post #7803 of 21315
no problem.
Yeah, several people have posted that the coax connection seems to get "hot". One man's hot is another man's warm. I have a OTA antenna, as I mentioned, but no direct cable connection. I have never noticed the antenna coax getting warm, but then again I am not back there all that much. But when I am, I have never even noticed that it was warm. Given that many have noticed it, I would not necessarily get too concerned, unless it is down right steaming. Then I might have an issue with it and consider trading it or getting the imput changed out if it was past the exchange period or if you don't have that as an option.
post #7804 of 21315
no problem.
Hmmm....my coax in's feel pretty hot. I don't want to have to go through another swap.....OY!!!
post #7805 of 21315
And make sure you bring the wife!!!!
post #7806 of 21315
My screen isn't bowed. Is the person talking about pincushioning?
post #7807 of 21315
What was your mfg date on your TV? Also, which model do you have, 5088 or 5688? I went through 2 5088's (from the same batch that were produced) back in June/July.
Why did I return them? Well, it was not because it was hot when the TV was on, but that it remained hot even after that TV has been off overnight!
I was thinking that it was a 5088 problem and I am about to pull the trigger on a 5688.
post #7808 of 21315
Mine says September 2006. It's a 6188
post #7809 of 21315
I just felt my COAX connections...TVs been off since last night, and they're pretty warm. Some of the other connections are slightly warm too. I'm guessing this is normal? Has anyone called Samsung?
post #7810 of 21315
NFLFAN, is yours hot even after it's been off?
mikeynavy, would you say it's just warm when it's been off or is it hot? Also, what TV do you have?
post #7811 of 21315
No, not when it's off....maybe just a slight bit warm, but barely noticible. Only hot when running. If others notice this too, then it is most likely normal. There is probably a good amount of heat in the back of these sets, and the coax connectors are thick metal. They might be prone to soak up more heat?
post #7812 of 21315
Sorry,
My 5688's coax connectors are warm to hot (depending on who's testing I suppose) with nothing connected to them (TV on). I can grab them without burning my self but they're definitely warm. Since metal conducts heat well and the bulb is pumping some heat out I'm not worried about it.
post #7813 of 21315
Mine is a 5688. They are warm when the TV is off. My TVs been on for about an hour now and like Feralhog says they're very warm to hot, but not to the point of burning myself.
post #7814 of 21315
Originally Posted by djoberg View Post
I have noticed this too on SOME wider aspect DVDs, but not on all. It hasn't bothered me though, as long as they maintain the same width all the way across. Some members have written in saying the black bar is wider on one side (in other words, the picture is tilted...bad geometry). I would NOT want to put up with that problem.
I changed my mind about it being the DVD Player....I think for me it is that I can't have my image centered vertically. If I do then I see screen garbage at the top of HD channels broadcasting in 4:3...especially HBO HD...but also ABC HD. I have to move the image up a bit to get rid of it. I think that made it such that when I play DVDs the top bar is smaller than the bottom. I think I see now why Samsung uses so much overscan...haha. Overscan off makes for somewhat better picture but at the expense of other issues.
post #7815 of 21315
Originally Posted by mikeynavy1 View Post
Ok...I just looked in my SM and for some reason my overscan option is greyed out...still at off...but now i can't turn it on. I want to make some picture comparisons. How do I get it changed again?
Entrer the sm while a different input is selected.
post #7816 of 21315
Hi All
My HL-S5087 arrived today. I've been luking in this thread since I ordered it from the "Bookstore".
My first impression right out of the box was disappointment. I immediately configured it with Eliab's settings and it took on a much cleaner look, especially in HD.
I found the picture quality better on component than with HDMI coming from my Cox 6412 DVR. SD looks acceptable on most channels.
Some questions I have are:
The image is tilted approx. 1/2 in. Is this something Samsung will send a tech out to fix?
When I switch from component to HDMI it says "weak or no signal" and then a few seconds later the picture appears. Anyone else see this?
I went into the Service Menu to check and adjust the centering and didn't find the setting. Would someone PM me the directions or post a link?
Mike
post #7817 of 21315
Originally Posted by Mikejl View Post
Hi All
Mike
The 1/2 tilt seems to be common. Some have tried pulling gently on one side of the top bezel while pushing on the other. Since the case is flimsy, it gives a bit and can correct the tilt. There is a more technical way to do it, but it involves replacing parts and a service visit. If you have the option, and it is really bad, ask for a new set.
The HDMI issue sounds like a handshake issue. As long as the picture comes on and stays on, that's fine.
I think the centering controls are in one of the top service menu sub menus...but I don't recall the name off hand.
post #7818 of 21315
Mike
My 6187 does it also, but only for about 1/2 second. Probably just a delay in the handshake from the stb to the tv.
post #7819 of 21315
heya.. one last question =P
i hooked up my computer to my S5087W and i noticed 1920x1080 doesnt fit on the screen.
i had to use nvidia's cp option of underscan to fit it in on the screen with a resolution of 1768x992. What's up with that? Wobulation?
And I noticed the left side of my TV is blurry (like the names of the posters on the left side) . So is the bottom. Is that normal for DLP? The middle of my screen is crisp.
Is it the resolution causing blurring or something? I dont think ive noticed blurring while watching TV. I tried 1600x900 and it still shows blurriness around the bottom/left edges.
edit: maybe it's my video card? i dont remember noticing any blurring there but it was a 19" LCD so i dunno :\\
post #7820 of 21315
Earlier today I posted about the 5087 I have on order and the precise dimensions that will fit in the wall unit I own. I still haven't had the chance to measure the TV in person but the specs provided by Samsung are consistent from the owners manual to the dimensional illustration to the website, etc. So I am fairly confident they are accurate.
After further measurements of the entertainment center, the TV seems to be a perfect match on width. There is an issue with the height but I can't decide how big of an issue I should consider it.
Judging by the height of the TV and the thickness of the bezel (0.75"), it looks like the front lip of the wall unit's bridge will overhang the TV by about 1/2 inch or slightly less. Hope this doesn't look to bad or cut off so much of the screen that it's unbearable.
I know, I can always remove the bridge but we'll see how it goes.
Still can't wait to get the TV!!
post #7821 of 21315
Originally Posted by Rijax View Post
First, I said nothing about the HL-S TVs. Since I was referring to sets that only last 3 to 5 years, I would have to be talking about sets that are 3 to 5 years old wouldn't I? The HL-S series is only months old. Their track record is unknown at this point. However, since I own an HL-S5687, I'm genuinely hoping their track record will be better than sets that are 3 to 5 year old.
Also, I don't believe I ever said these sets would be "useless." I'd appreciate it if you wouldn't put words in my mouth. I said they won't last, i.e., they won't last more than 3 to 5 years without failing. If you wish to have them repaired, you can go on using them indefinitely.
Well, I sincerely hope you have an extended warranty for your set. The information which prompted that statement comes from personal experience, the experience of a number of my friends, and many posts on this forum.
I bought my first HDTV in 2003 (43", 720p, HLN Sammy, no extended warranty). Earlier this year (May?), with the set out of warranty, the picture would just disappear. I called Samsung and had a tech come out and look at it. The diagnosis was a repair that would cost more than the set is worth. In fact you could buy a brand new 42", 720p Sammy for about the same price as the cost of the repair. Time for a new set.
Are there those whose 3 year old set is working fine? Absolutely! But, based on numerous other posts here on the forum, I'm hardly the only one who has had this experience. In fact, I have a friend who had an LCD die on him with the same results ($3600 HDTV - $2500 repair. He bought a new set). And, he has a neighbor who had a different brand of LCD fail on him (he bought a new set). I would submit that these new technologies fail infinitely more often than the good old CRTs.
So, basis #1 for my statement: Cost of common repairs more expensive than the value of the set.
Lets go back to those with 3 year old sets that are working just fine, or those who were prescient enough to purchase an extended warranty. Do they have HDMI inputs? Are they 1080p? The technology is changing so fast that, though still functioning and usable, these sets can reasonably be considered obsolete within a 3 to 5 year period. Obsolete does not mean unusable. It just means outdated. I know of a number of posters here on the forum who have replaced their sets several times simply because of new technology.
Basis #2 for my statement: Rapidly developing technology renders the older sets obsolete.
Lastly, if you're going to accept the "$300" to "$3000" as a generality regarding price, why take the 3 to 5 year range so literal. It was meant simply as another generality? Sheesh! My point is, these new technologies are in their infancy and are experiencing growing pains. Do these new HDTV sets cost significantly more than the old CRTs? It's undeniable! Do these new HDTVs last as long as the old CRTs. So far, I feel their track record, in enough instances to be considered significant, has demonstrated that is not the case. Will this improve? I certainly hope and expect it to. But, keeping in mind that they haven't been around long enough to tell, their failure rate, to date, makes the assertion that they won't last 10 to 15 years, as my as my old CRTs did, not exactly unreasonable.
Now I get it. Of course readers should not react to what you actually wrote, but rather to what you actually meant. Thanks for the clarifying lecture.
post #7822 of 21315
Then what good is it?
Regarding the "hot" RF connections:
88 degrees for the cable, 80 degrees for the antenna when the unit is in standby (measured with a IR thermometer). On, I would venture 110 degrees.
Yes, they get hot. Not warm, which is something above room temperature, but hot. Not enough to burn you of course, but for a RF connector on any device I have never felt any other get that hot before.
No, it's not the 'lamp', it's the circuitry on that on that board with the tuners. As you can see those two RF connectors go to a switch for the analog and digital tuners. Not sure which is which though. The first two photos are from the '79' series which should be the same for the '88'. The third is from the '87'. Notice the single tuner and the missing connector along side.
post #7823 of 21315
Yes, they get hot. Not warm, which is something above room tempurture, but hot. Not enough to burn you of course, but for a RF connector on any device I have never felat anything get that tempurture before.
No, it's not the 'lamp', it's the circuitry on that on that board with the tuners. As you can see those two RF connectors go to a switch for the analog and digital tuners. Not sure which is which tough.
Thanks for the detailed answer on this! That was really helpful. Hope you didn't take your set apart just for me (no, I know where they came from in the tech links section)
post #7824 of 21315
Yea, but when I got it back together I had parts left over.
The images were cropped from both SM's.
TV Guide question.
I have both OTA and cable, I set the Guide for cable, but it keeps on reverting back to OTA. I have DVR with the same setup and there isn't a problem. Any ideas?
post #7825 of 21315
TV Guide question.
I'm not sure about this, but does TV Guide work with cable, or just OTA? I wasn't sure where it downloaded its information from
post #7826 of 21315
Originally Posted by Eliab View Post
A properly performed calibration will lessen the light output of your display which does in fact contribute to RBE perception. It'll do this by adjusting the gamma, brightness, contrast, and minimizing the iris. However, I don't think that you should risk spending the money on a calibration in hopes of not being bothered by the RBE anymore as that won't likely be the case (although it may be reduced).
Eliab
Thank you very much for taking the time to respond to my questions, Eliab.
My RBE experiences are maddening with respect to there inconsistency.
I watched SIN CITY the other night, the so called "worst case scenario" and I think I saw rainbows maybe 3 times in the whole movie. However, then I'll see it in a regular TV show from people just walking around in black suits and white ties.
The only relatively consistent RBE I experience -- scrolling white on black.
I love what this TV does and I don't know where I'd go right now as an alternative hdtv (Sony?, which =s $$$). Therefore I'm considering (depending on my tolerance over the next few days) keeping it and possibly selling it next year. I believe I got a pretty good price on it and I may not lose that much in resale, but that decision is not final.
post #7827 of 21315
TV Guide question.
I have OTA and cable. I set it up for cable only and TVGOS works fine.
Frank
HL-S5688
post #7828 of 21315
.............When I switch from component to HDMI it says "weak or no signal" and then a few seconds later the picture appears. Anyone else see this?.............
My 5688 does the same thing.......
post #7829 of 21315
Count me in on the group.
post #7830 of 21315
Ok, here is a hard one to explain:
Anyone elses notice that on really bright sky or white scenes that the background sometimes has faint horizontal lines...like hairline thin....they almost look like CRT scanlines. You may have to get up closer to see them. I am not sure if it is the source material....or a characteristic of the display....I just want to make sure it isn't a defect.
  Back to Forum: Rear Projection Units
