Originally Posted by Azalo
thanks for replying and yes i am entering the full digital number. i talked to samsung and apparently it is by design that it won't allow you to go to a channel that it hasn't found in the autoscan. my main problem is with NBC and CBS it usually either finds one or the other, but i have nbc right now so i'll probably just leave it since i mainly want to watch, Heroes, Lost and Sunday Night Football in HD, don't really watch any CBS shows.
If the tuner has not found a given digital channel on the last scan, then it doesn't know anything about that channel. You then have to enter the actual channel number of the digital channel.
For example, say analog channel 6 broadcasts a digital signal on channel 56. If channel 56 was received in the last scan, then the tuner will know that virtual channels 6-1, 6-2, etc., can be received by tuning to channel 56. If the tuner didn't receive channel 56 on the last scan (perhaps it was off the air, or the signal was weak), then the tuner can't relate 6-1 or 6-2 to channel 56.
The solution is to manually tune to channel 56. If it is receivable, it will then display as channel 6-1. Once channel 56 has been received, it can subsequently be tuned by entering 6-1 or 6-2. If you don't know the actual digital channel number, they can be found at many sites on the internet.
![Disney WOW: World of Wonder [Blu-ray]](http://cdn.avsforum.com/d/da/50x50px-ZC-dadc69a0_B0045ASBLG-51TziBcqZFL.jpeg)
Just use the res for one of the 720P tv's. It will look much better.
PM me for more info.
.. But its all good since the 5 year extended warrenty covers it. Buy the TV somewhere else that you can get a better warrenty. Somewhere local like a Best Buy or CC would be ideal.
time on our order and it sounds like we are not alone. Take it for what it is worth.
