Originally Posted by
s2silber
I've got that same Patricia Barber SACD and I never experienced that problem. However, the Denon firmware update that a couple of our European friends in this thread have mentioned is supposed to fix disc compatibility issues. It's the version three release of the original software. I think if you got a hold of it that would solve your problem.
thanks for your input! I believe we are on the same "wave-length" because I was thinking the same thing.
I had never experienced any issues with this disc, or any others, with my Sony player. These high-resolution Patricia Barber disc's are some of the more high-quality manufactured products.
Also, I just remembered this problem happened one other time, a week ago, while playing a different SACD disc. It behaved almost as if it were "skipping", then audio pretty much cut-out. I figured it was an "odd" disc that was bad (but it was new, never played before that). Now I'm beggining to believe this may be a disc compatibility issue.
I remember a few weeks back a member, from Canada, posted that he had contacted Denon (by e-mail I believe), and they sent him a firmware update disc. I would like to do this.
