I've been doing a series of posts on another forum about the HA stuff I'm doing, was asked to duplicate that here as it's all integrated with the HT stuff. Anyhow, not sure anyone here cares, i'll update as I go.
To keep it simple for me to do, i'll just copy/paste each post here. There's only a few so far.
Post #1: 4/2/06: And so it begins...
I've done some stuff around the periphery of HA, got an irrigation controller connected to CQC [not yet controlling my actual sprinkler system, still working through some cable-creation kinks], an aprilaire HVAC [but I broke the RS232 adapter by mistake].
But today I made a HUGE step forward, thought I'd share. BTW, this is all with my el cheapo SageTV/DVD/CQC Server that I use for the home theater thing. I can't believe my 3yr old budget Asus mobo and 512MB RAM is the engine behind my whole house. I have an AMD2500 in it, but it rarely goes above 15% CPU, usually ~5%.
I bought an Elk automation panel. Think ADT on steroids, and much cheaper to boot. You can get the "ez" version of it for pretty cheap, $350, or even less if you're a CQC customer. It can control security, HVAC, lighting, doorbell & telephone ring detection [and since it's integrated with the HT thing, i'm hoping to pause audio/video], a ton of other stuff. I paid $2.50/each for window sensors, whereas ADT wanted $100/each. I'll be putting Window/smoke/motion/heat/CO/flood/...., throughout the house. I think all the sensors total will cost me <$700. Granted, a crapload of time to do the wiring, but that's the fun part.
So anyhow, i'm tired and I digress. Today I got the panel hooked into the CQC Server via RS232, mounted the keypad, the voice-box, and a remote temperature module. I was so excited, I pulled out the architectural drawings for my house, mocked that up in photoshop, and (of course) found a piece of art for the backdrop.
