AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Software › HD-DVD Authoring to DVD -/+ Media
HD-DVD Authoring to DVD -/+ Media - Page 44
post #1291 of 1475
texmex, did you get my pm so that you can send me the HD-DVD folder via yousendit ?
post #1292 of 1475
Originally Posted by Arpeggio View Post
I wonder what Toshiba thinks about all this?
Hush. Nobody tell them, OK?
post #1293 of 1475
Originally Posted by Hyrax View Post
If anyone wonders what happens when you 'shrink' a 13.5 GB file to fit on a 8 GB disk
Ouchie.
post #1294 of 1475
Originally Posted by RockStrongo View Post
Hmm, T2 is wmv isnt it?
Yep but the DRM on it could make things difficult.
post #1295 of 1475
I don't know about you, but I'm a bit uncomfortable with the posting of what is being written to disks. Seeing it in writing may make it seem scarier, and stop the development of better consumer tools.
post #1296 of 1475
Some really great archives....
Thanks. :-)
post #1297 of 1475
Kipp -
LOL... Your posting has his entire posting, so even if he edits/deletes his post, the offending bits remain being posted.
post #1298 of 1475
Too late!
Honestly, release those movies on HD DVD and the quality won't even compare. Plus we'll ALL buy them!
post #1299 of 1475
To Joseph Clark & all others who've made this possible, a big thank you! I made my first HD DVD using a 5 min DVHS capture & it worked like a charm! No jitter & w/DD5.1.
Sorry if this has been asked before, but being new to all this, including capturing hi-def to PC, how can I tell if a TS file will fit onto a dual-layer DVD blank? Or that a DL & a SL blank is needed for a certain TS? How do you know where to split the TS? Thanks.
post #1300 of 1475
Sure we'll buy them, but lets clean these post (and quotes) up and keep this thread open. I'd love to see a great sticky out of the important stuff.
post #1301 of 1475
Question - When converting my TS files to an mpg in MPEG-VCR, something happens to the soundtrack.....When watching the mpeg, at first the sound is fine, but slowly gets out of synch....by the end, its way off.....the TS doesnt have this problem so it has to be MPEG-VCR....is there a setting that im missing? Anyone have this issue?
post #1302 of 1475
Originally Posted by docchak View Post
I agree,with all due respect, there is no need for flaming, mistake has been made,and we realize that,after all it's just coming from one got excited about what this thread has to offer, we are all human being, I suggested that all related posts be deleted / clean up. I will delete mine in a little bit.
My post is history in a minute.
post #1303 of 1475
RockStrongo,
I had the exact same issue until I switched over to VideoRedo Plus. I also did away with using HDTVtoMPEG as it seems to cause all sorts of issues for DVD Movie Factory 5.
Now all I use it VideoRedo Plus and Ulead DMF 5. Unless I need to do the 1088 fix.
post #1304 of 1475
RockStrongo,
Ill give VideoRedo a try..thank!
BTW - Anyone know how to open multiple TS files in redo? or do I have to combine them before?
post #1305 of 1475
Hey guys, sorry if this has been asked before, but...
Are you getting an OSD on your discs? Mine are showing up as HD DVDs, but when I hit pause/play/rewind/ff, it will show the OSD like a regular DVD. Is this happening to your discs as well?
post #1306 of 1475
I did, and I tried to send the file yesterday, but I had a switch go bad on my network mid-transfer. I managed to fix the problem, but didn't get another chance to send the file before I left.... for vacation. I still might be able to get it to you tomorrow or Monday. I'll let you know if I get it sent. Sorry for the delay.
texmex
post #1307 of 1475
Kipp -
Did you not see the"edit" option???
post #1308 of 1475
texmex
No problem texmex, thx !
post #1309 of 1475
Guys, I've done a search & can't find an answer to this. How large a TS or MPG file will fit on a double-layer & a single-layer blank DVD? This is assuming I don't create a menu. Trying to determine where to split the TS or MPG file. Thanks.
post #1310 of 1475
Both Movie Factory 5 and VideoStudio 10 re-render MPEG HDTV clips, which takes a long time and of course diminishes the quality.
Is there a way to avoid recoding? The "Do no convert MPEG..." box is checked, but this has no effect.
Am I missing something obvious? I tried making MPEG files with both Womble and VideoRedoPlus.
post #1311 of 1475
Has anyone seen this yet?
http://www.compusa.com/products/prod..._HD_DVD_Player
Might make most of this moot.
post #1312 of 1475
Originally Posted by cal87 View Post
Has anyone seen this yet? Might make most of this moot.
Yes, most have. No, it won't. That's not a HD DVD player.
post #1313 of 1475
Yes I know it's not a HD DVD player. What it seems to do is read a DVD containing ts or wmv files if I am reading the ad correctly. I know previous network players can do this stuff over the network, but not actually read it from a DVD. So if you have archived ts or wmv or other HD files onto DVDs, there is no sense converting it to a true HD DVD.
post #1314 of 1475
Originally Posted by Kipp Jones View Post
So when we get blank HD-DVD media, can we still use the same methods to burn material or will the DVD drives not recognize the media?
Anyone know???
post #1315 of 1475
acording to the tech spec:
DVD/CD Playback Formats Supported:
Audio CD
CD-R
CD-RW
DVD
DVD-RW/-R
DVD+RW/+R
VCD
HD-DVD
Well, looks like it will do HD-DVD but will only do MPEG2-TS (HD 720p),wonder what happen to 1080i or 1088 that is.??
But $199 tag, that's more like it, wonder how long will it take to boot up??
post #1316 of 1475
Anyone know???
Regular DVD recorders won't recognize the media. We can still use the procedure, but we'll have to use it with a true HD DVD recorder when the HD DVD recordables come along.
Guys, I have the last piece in place for the guide now and it will be up later today. Sorry this has taken so long. I had more computer related problems because of the storms here in St. Louis. Remember that you can make changes, so as soon as it's posted, let me know what I missed.
post #1317 of 1475
8000MB is a safe number if you dont use a menu
post #1318 of 1475
make sure your file is 1920x1080i60 and make sure to adjust the HD DVD settings to match in VS/MF5
post #1319 of 1475
Audio CD
CD-R
CD-RW
DVD
DVD-RW/-R
DVD+RW/+R
VCD
HD-DVD
This looks like the same old LinkPlayer to me, except the CompUSA ad has HD-DVD listed as a supported playback format. Note that it's not HD DVD. I think this is the same old red laser player Avel has been selling for a long time. As such, it won't play true blue laser HD DVDs. This is deceptive advertising. Note also that it doesn't have DVI out, just analog.
post #1320 of 1475
My file was indeed 1920x1088, and using fix1088 before converting it to MPEG was enough to make Ulead stop re-rendering it.
Thanks for the help!
  Back to Forum: HD DVD Software
