Originally Posted by Hyrax
I've been trying to use x264 for the past two weeks and all I get is errors, like this:
Job is a dgindex job. dgindex commandline:
"C:\\Program Files\\GordianKnot\\DGMPGDec\\DGIndex.exe" -AIF=[E:\\Recode\\Bountiful.mpg] -OF=[E:\\Recode\\Bountiful] -exit -OM=2
successfully set up dgindex
Processing ended at 11:40:58 AM
Log for job job1
Cannot open d2v file, 'E:\\Recode\\Bountiful.d2v'. Error message for your reference: Script error: there is no function named "DGDecode_Mpeg2Source"
Applying force film failed.
The odd thing is that the file 'E:\\Recode\\Bountiful.d2v' does exist. I assume that I am doing something wrong, perhaps in my set up of x264. I downloaded the latest build (x264-517). Do you mind taking a moment to help me - or to at least push me in the right direction? Thanks in advance.
Edit: I believe I found the problem. MeGUI needs to be in the AVSynth Plugin folder.
Log for job job1
So is it working? I don't have MeGUI in the AVSynth Plugin folder and it works fine. Make sure all your Programs Paths are all correct under the tools/settings tab of MeGui. Also be sure you get the latest version of MeGUI to go along with the latest version of x264.
On another note. Does anyone know what the HD-DVD structure is like for h264 encoded movies? Does it follow the same structure as the earlier mentioned HVDVD_TS folders?
